HELPP!! BROKEN TAILGATE HANDLE, TAILGATE WONT OPEN
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OB.BAJA, Nov 11, 2010.
  1. Nov 11, 2010 at 8:32 PM
    OB.BAJA
    OB.BAJA [OP] Well-Known Member
    Obed
    SoCal
    Ok im freaken out...went to costco a few minutes ago and right before i was about to load some stuff in the back, i realized that my tailgate would not open. the handle seems a little bit loose and nothing happens when i pull it....does any one know how i can fix it....
    thanks
  2. Nov 11, 2010 at 8:41 PM
    OB.BAJA
    Obed
    SoCal
    Yeah i had check that out but, im not sure if i will be able to take off the cover since the tailgate is closed :confused:
  3. Nov 11, 2010 at 9:46 PM
    OB.BAJA
    Obed
    SoCal
    just checked it out looks like the right clamp is stuck shut. I will try get some wd40 in there hopefully it work. fingers crossed
  4. Nov 11, 2010 at 9:57 PM
    bowstoy
    bowstoy New Member
    harry
    okeana ohio
    05 tacoma
    mine did the same thing went to toyota and ordered the red and black clips that are rite behind the tailgate handle under the liner only bout 7 buks took 1 day to get easy to install
  5. Nov 11, 2010 at 10:25 PM
    OB.BAJA
    Obed
    SoCal
    took the cover of to see what was going on pulled the two rods and only one right side is opening the other size is totally seized:(
  6. Nov 11, 2010 at 10:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I loled at that ^^
