Helter Skelter advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rocket86, Jan 28, 2025.
  1. Jan 28, 2025 at 1:24 PM
    Rocket86
    Rocket86 [OP] Well-Known Member
    2002 taco changed driver side door handle. Now windows work perfectly.
    Electric locks only the passenger works. Drivers side works sometimes? Key fob works every time? I even bought a OEM driver side master controllers? Thank you.
    It tries but just doesn’t do it sometimes?
  2. Jan 29, 2025 at 8:21 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Does the electric door lock activate all the time or only sometimes?
    If it always activates, I would check for looseness in the linkage between the actuator and the door lock mechanism.
    Black97v6MT likes this.
  3. Jan 29, 2025 at 6:00 PM
    Rocket86
    Thank you it does try every time it just seems to catch on something and when I use the key to unlock it or lock it it like it catches. There’s some kind of catch there
  4. Jan 31, 2025 at 9:02 AM
    skeezix
    Colorado
    1998 Limited
    I would pull the door panel off and have a look at the linkage to/from the lock mechanism. See if any rods are loose when you push them towards and away from the door jamp. Maybe something is preventing them from moving all the way???
