here it comes! stupidest question ever
Discussion in 'Technical Chat' started by 08pretaco, Feb 7, 2010.
  1. Feb 7, 2010 at 6:30 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    has anyone in any manual transmission replaced their over drive gear?
    im looking at a transmission picture of just a traditional 5 speed manual and was curious if exchanging the over drive (5th) for a smaller gear would lower your cruising rpm's? if so how feasible or practical is it?
    and i know it might seem like a stupid question but its something i have kind of always wondered and please im not really in the mood for sarcastic responses unless its a really good one :eek: thanks
  2. Feb 7, 2010 at 6:33 PM
    beetlejuice2275
    beetlejuice2275 Well-Known Member
    Reximus
    Queens, NY
    Drift inspired 08 Reg Cab
    custom ram air. blacked badges, hids, rewired front turn signals and park lights, URD short shifter, Pioneer t-screen (no nav), 10" 1200 watt.
    put up the picture you're looking at.
  3. Feb 7, 2010 at 6:36 PM
    08pretaco
    Oliver
    az
  4. Feb 8, 2010 at 11:06 PM
    RWS_350MAG
    RWS_350MAG Well-Known Member
    Don
    Wisconsin
    2010 TRD Off Road 4x4 AC
    Toytec Ultimate lift, Tailgate anti-theft mod, 265/75-16 Goodyear Duratrac tires on stock rims, Lakeland Predator Cap, Rear seat headrests removed, Husky Floorliners
    Its not really a stupid question.
    You could change the overdrive gear, but you would also need to change the idler, or final output gear to compensate for the difference in gear diameters.
    I doubt that a gearset would be available from the factory, even from other model vehicles. So that means that a gearset would have to be custom made. You would need to figure out the tooth count for both gears, helix angles of the gear teeth, as well as material and heat treat properties.
    In a nutshell, it would be more trouble that what its worth.
  5. Feb 8, 2010 at 11:08 PM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
    Wouldn't changing your rearend ratio be a better idea???
  6. Feb 9, 2010 at 7:27 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Changing the final drive ratio at the differential would be more straightforward and probably cheaper, though it wouldn't have exactly the same effect.
  7. Feb 9, 2010 at 8:08 AM
    08pretaco
    Oliver
    az
    ya i guess^
    to the rest: i want to do 4.56 when i get some 295/75 and all i want to do is change overdrive. i dont want to put <4.10 in my diff cause then the truck will turn into a doggg (even moreso than it is). im not looking to change all characteristics just that of the overdrive
    changing the gears in the diff to < 4.10's would make my highway rpm's lower but then around town would suck, therefore changing the overdrive gear would only affect that, overdrive? is that right?
