Here's an odd one-HVAC
Discussion in '1st Gen. Tacomas (1995-2004)' started by dispatch55126, Sep 26, 2014.
  1. Sep 26, 2014 at 2:51 PM
    dispatch55126
    dispatch55126 [OP] Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    I just replaced a light bulb in the HVAC controller and now all I'm blowing is hot air (literally). All of the other controls work and yet when I turn the temp dial, I go from hot to very hot.
    Any ideas?
  2. Sep 26, 2014 at 3:12 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Maybe you knocked the control for the AC loose, have you had it back out to verify everything is hooked up correctly? I had mine out for the same issue and when reinstalled I had no issues.
  3. Sep 26, 2014 at 3:16 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    :facepalm:Yeah, that's what it was.
    I pulled the console off again and the HVAC control cable wasn't fully inserted into the controller. It works just fine now.
  4. Sep 26, 2014 at 3:27 PM
    Darryle
    Darryle
    Weatherford, Texas
    Good deal, it had to be simple just because of the time line.
  5. Jun 12, 2015 at 3:10 PM
    loadmaster0219
    loadmaster0219 Active Member
    MS Gulf Coast
    08 TRD Offroad
    KnN CAI, flowmaster, Toytec lift kit, 285-75-16 BF Goodrich rugged terrain TA, DC Grenade rims, halo headlights, bilstein 5100s all around, new OME leaf pack for rear, swing box for bed, Fab4 rear bumper, satoshi grille
    Where did you find the bulbs? I tried doing an LED upgrade to it but it would not light up...not sure what happened. Either way i am still trying to find replacement bulbs for the HVAC display.
  6. Jun 12, 2015 at 3:33 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    led bulbs only work one direction, if they don't like simply turn them 180 degrees and then they will work.
    read the dash light mod thread
