Here's how much my truck got lifted.
Discussion in 'Suspension' started by Drewski, May 9, 2014.
  1. May 9, 2014 at 8:39 PM
    Drewski
    Drewski [OP] Well-Known Member
    People's Republic of Chicago
    '99 Prerunner SR5 Xtracab 4 cyl auto
    This much.
    So yeah, after about 4 months of delay delay delay, I finally got everything together to freshen up the sagging suspension on my '99 Pre. The rears were the standouts - the leafs were frowning. The front coils seemed to still hold their own, but the stock shocks were obviously crapped out. I ordered the typical Bilstein package, (5100/5125) for stock height applications. I also did the two leaf add-on for the rears with the intention of only raising the rear back up to stock height. We had some hang-ups working on the rear, mostly due to being unfamiliar with this particular truck. Or mostly due to the proximity of my friend's budding microbrewery (in the next building over). Either way, it was clear after we buttoned it all up back there, that the springs were too much for the "stock length" shocks. I.e., if I pull the bottom bolt on the shock while the wheels are on the ground, the shock will only extend another 2.5" or so. Not much droop there. Of course, my truck is city use only, and I don't expect any mad articulation like back in my Jeep days, but still, I would've rather done it right the first time, and I obviously can't trade in the shocks for longer ones.
    Seeing that this would be a "rake" issue, I moved the snap ring on the Bilsteins to the middle setting and swapped out the fronts. I still have more rake than I expected (sorry my animation above isn't perfect so it's hard to see) which doesn't bother me aesthetically as much as it does functionally, I guess. I didn't want to use the full lift setting on the front Bilsteins at the time, as I'd read enough bad reviews about preloading the stock springs that much on this truck. If it wasn't such a pain in the ass to adjust them now, I'd probably go back and adjust them anyway, but whatever.
    There's no doubt the truck does ride smoother - relatively speaking of course. The front used to bounce like mad over certain speed bumps for example... not anymore. The rear seems to ride better, but I have noticed some kind of mild vibe in the driveline in the 15-25mph range though. It's odd, hard to describe. Definitely doesn't feel like the driveshaft vibe I recall from my early days of Jeep lifting, and I don't see an obvious pinion angle issue.
    I don't know that I'm going to crawl back underneath to change anything though, after all this isn't some off-road rally wanna-be or compensation/mall cruiser lift attempt; it's a city DD with a tired-ass stock suspension that needed some new life.
    By the way, I measured the rim-to-wheelwell dimensions before I did the work, so I would be able determine exactly how much it raised up. I saved those measurements on my phone. And, you guessed it, my phone froze up for the first and only time in 1.5 years in the middle of this @#$%ing project, and I had to do a factory restore to get it working again. Which means, that data is gone and I don't know what the measurements used to be. :mad:
  2. May 9, 2014 at 10:20 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Sweet gif.
  3. May 9, 2014 at 10:22 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    is it bad i was more intrigued by the surroundings changing.
  4. May 10, 2014 at 5:44 AM
    NEMESISVETTE
    NEMESISVETTE Well-Known Member
    I see you added a fence. lol
  5. May 10, 2014 at 6:25 PM
    mikegli
    mikegli Well-Known Member
    Orlando
    04 Tacoma TRD
    No wonder it took so long to get the suspension done!
  6. May 18, 2014 at 8:24 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    How many changes can you see???? I think I se 7 or 8..
  7. May 18, 2014 at 8:28 AM
    shr133
    Muskego, WI
    2010 V6 Sport
    I went with the full OEM lift to upgrade my suspension and went for a 2" lift in the front. the ride is much better on and off road...
  8. May 18, 2014 at 8:29 AM
    DoccoM85
    DoccoM85 Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Has to be a completely different location, if not im impressed, you built a house in the back yard, a fence, installed new siding, and merged garage doors!
  9. May 18, 2014 at 8:31 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    It looks like your truck is breathing :p Nice job
  10. May 20, 2014 at 11:48 AM
    jstcantduXty5
    jstcantduXty5 Active Member
    James
    NH Mountains
    4x4
    Leer cap.
    You guys are cold.
    Be serious.
