Here’s a new one, leaking steering column
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5nahalf, Nov 26, 2019.
  1. Nov 26, 2019 at 8:42 AM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    this morning I noticed some oil on my floor mats, the steering column is leaking :)
    Going to bring it into the dealer hopefully tomorrow if they have a apt.
    gtpowers and The hammer like this.
  2. Nov 26, 2019 at 8:56 AM
    ryan760
    ryan760 Well-Known Member
    Well thats a new one. Where is it coming from exactly, can you tell?
    Big tall dave and GreyBaldTaco like this.
  3. Nov 26, 2019 at 9:00 AM
    5nahalf
    Erik
    Minnesota
    It looks like it’s coming from the area right next to the sticker in the first picture. I didn’t look too hard though as I was on my way to physical therapy.
  4. Nov 26, 2019 at 9:05 AM
    5nahalf
    Erik
    Minnesota
    Looks like it could very easy drip onto the brake pedal.... oil covered brake pedal is not a good thing.
  5. Nov 26, 2019 at 9:07 AM
    tcjacado
    tcjacado Well-Known Member
  6. Nov 26, 2019 at 9:07 AM
    ryan760
    Please keep us up to date
    over60 and TnTuna like this.
  7. Nov 26, 2019 at 9:16 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Does the steering column contain oil in a sealed area? That is odd. I’m wondering if it’s just excessive assembly grease that may have “sweated” out. Maybe due to use of the footwell heater during these colder months? If that’s the case you shouldn’t see much more come out and you can wipe away any residue.
    you have my curiosity.
  8. Nov 26, 2019 at 9:16 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    MT or AT? Check your master cylinder and any other fluid containing holders attached to the firewall on the driver side for obvious signs of a leak. ??
  9. Nov 26, 2019 at 9:37 AM
    tcjacado
    It has a piston assembly for the tilt/telescopic movement in the steering wheel. If you unlock the steering column with the little lever on the bottom of column and reach down under the dash and grab that silver thing with the sticker on it. Then move the assembly up and down and so forth you can feel it move around.
  10. Nov 26, 2019 at 9:45 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That is a dry assembly and usually is assembled dry as well.
    The only thing which I presume could be causing you issues there is if they used some sort of lube to assemble it and the excess sweated out as previously mentioned in which case you are fine...
    Or
    Your master cylinder for brake fluid is starting to leak out as previously mentioned, which is the more likely scenario here.
    I would clean up the fluid and just monitor it. If you see if again, you got an issue.
    Big tall dave likes this.
  11. Nov 26, 2019 at 9:54 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Can't believe no ones asked yet... Maybe it's coming from the turn signal stalk... Blinker Fluid... Can't believe I wrote that but there it is...
  12. Nov 26, 2019 at 10:10 AM
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    o_O
    12TRDTacoma likes this.
  13. Nov 26, 2019 at 10:40 AM
    GHOST SHIP
    GHOST
    #fancythirdgens
    AllTacosFloat and 12TRDTacoma like this.
  14. Nov 26, 2019 at 11:05 AM
    5nahalf
    Erik
    Minnesota
    Its a auto, the only fluid noises I hear in my truck is when I push down the brake I hear fluid squeaking, but its dont that since new.
    This fluid must of come out this morning as it was wet when I took the pictures, but its soaked into my floor mat now.
    Ive had my heater on for nearly a month now, and it leaked out in the morning after the truck sat all night. So its not a heat thing.
    I have a apt tomorrow to get this looked at and have my 40-50mph shudder taken care of.
  15. Nov 26, 2019 at 12:05 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Good point. I like to use Valvoline Max life, works great!
  16. Nov 26, 2019 at 2:22 PM
    GoldenBrew
    Golden, Colorado
    check your brake fluid reserve reservoir and see if it is above the minimum line. Sounds to me like it is the master cylinder failing - which pulls fluid from the referenced reservoir. Thought I read somewhere on the 3rd gen thread there was a recall for some related to failing master cylinder. When the master cylinder fails your brake pedal will go to the floor and you will have no brakes.
    ScrippsRanch67 likes this.
  17. Nov 26, 2019 at 2:24 PM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    lube sweating from column..
  18. Nov 26, 2019 at 2:27 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Also works as power steering and transmission fluid.
    Junkhead[QUOTED] likes this.
  19. Nov 26, 2019 at 2:31 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I would recommend a complete column flush. Why take chances. :notsure:
  20. Nov 26, 2019 at 2:32 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    In for an answer.
    sdsurfer likes this.
