Herky Jerky
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sikora8, Jun 1, 2015.
  1. Jun 1, 2015 at 2:08 PM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    My wife has a 2012 TRD with a 3" Bilstein lift and 18" Toyo R/T tires. Since it's her truck, per say, I don't drive it much. Although, I took it out yesterday to check my cattle and realized a noticeable jerk in the steering wheel when traveling at a slow speed on a gravel road. The jerk is quite noticeable but no squeak, clunk or any other noticeable indicators. Any idea where to begin? All appears tight at first glance. Thanks
  2. Jun 1, 2015 at 2:09 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    so you are traveling straight and then it jerks you to the left or to the right? :jerkoff:
  3. Jun 1, 2015 at 2:10 PM
    sikora8
    04' SR5
    Absolutely...quick jerks in either direction.
  4. Jun 1, 2015 at 2:11 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    do you have after market upper control arms?
  5. Jun 1, 2015 at 2:12 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Was there a good alignment done after the lift?
  6. Jun 1, 2015 at 2:13 PM
    sikora8
    04' SR5
    I'm not completely sure....we've only had it for a month and we purchased it modified from a dealer.
  7. Jun 1, 2015 at 2:14 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    take good pictures of your suspension, shocks ucas and all and post them up here
  8. Jun 1, 2015 at 2:16 PM
    sikora8
    04' SR5
    I will...she'll be home from work in an hour or so and I'll post. Thanks
  9. Jun 1, 2015 at 6:49 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Well there's your problem right there.
  10. Jun 2, 2015 at 5:44 AM
    sikora8
    04' SR5
    I appreciate your insight there Captain Obvious but I'm here seeking suggestions and not your infantile sarcasm. I apologize for not getting the pics up last evening as it was a horribly rainy day here. Is it everyone's general consensus that a faulty UCA would cause these short, violent jerks? Thanks
  11. Jun 2, 2015 at 6:19 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Touchy sikora8, it's an internet forum. Chill pill, calm down. He means you have no idea what is under the body, so you don't have a clue yet. Post lots more solid well thought out information with pics. Coulda done that first, Internet troubleshooting with no info always gets you the 'fun answers'. I think it's the blinker fluid.
  12. Jun 2, 2015 at 8:02 AM
    Pigpen
    Dan
    Northwest Montana
  13. Jun 2, 2015 at 8:05 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    FTFY :D
  14. Jun 2, 2015 at 8:11 AM
    Pigpen
    Dan
    Northwest Montana
    Sorry for the obvious, but it's not in 4wd right?
    Jerking on straight driving, turning...?
    I would guess lifted too high for stock UCAs, perhaps amplified by spacer lift when your uses need a real lift.
