Hesitant shifting when cold 24 SR5
Discussion in '4th Gen. Tacomas (2024+)' started by Egarr12, Dec 22, 2024.
  1. Dec 22, 2024 at 4:40 PM
    Egarr12
    Egarr12 [OP] Member
    Easton
    2021 Silver Tacoma TRD OR
    2024 SR5 4x4 18k miles. Getting colder in TN especially in the mornings, I typically let the truck warm up for a few minutes so its ever so slightly warm when i get in, and upon driving the trans always seems somewhat hesitant to shift. I didn't know if it was holding a gear to warm up but when ever it seems to finally upshift its not a smooth shift it feels like it just falls into the gear. after it warms up its fine but it doesnt seem to like the cold much. Anyone else experience this? couldn't find anything else about it on the forum.
    Gfenza89 and 2016Tacoman like this.
  2. Dec 22, 2024 at 4:45 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea, mine has the same behavior. It gets really interesting when it's below 25°. Nothing bad, but definitely "funky".
    Gfenza89 likes this.
  3. Dec 22, 2024 at 5:00 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I kind of recall CVTs reacting to the cold and not shifting the same or almost not at all. Most auto trans are going to shift differently depending on temperature.
  4. Dec 22, 2024 at 5:25 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    All The Auto Toyotas I’ve owned do this until the engine/trans temps come up.
    TurboDA6 and gmtech like this.
  5. Dec 22, 2024 at 5:56 PM
    Gamma11
    Gamma11 ((‘)) yea, i like the taste
    Andrew
    Northeast
    2024 DCLB OR Bronze Oxide, 2022 T4R ORP Super White
    Nothing weird with the trans but my wiper motors were loud this morning in -10f temps… thought that was odd
  6. Dec 22, 2024 at 7:13 PM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    My 2nd Gen has done this for the 14 years that I've owned it. My 4th gen not so much.
  7. Dec 22, 2024 at 7:15 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    My jeep and gm vehicles have always done this.
  8. Dec 23, 2024 at 2:06 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Mine does it too, just let it warm up for a couple minutes.
  9. Dec 23, 2024 at 3:04 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    <laughs in upstate VT>
    ....sorry couldn't resist...
    Memphis
    Current Weather
    5:51 AM
    39°
    Home Area-ish
    Current Weather
    5:53 AM
    0°F
    Haven't paid much attention, but just for point of reference -
    Is the new trans oil the existing historical magic gold juice the previous gen(s) had? I would think they'd even go slightly thinner to get every last 0.00001 mpg out of it.
    A manual clutch at -30 was also fun at times. The auto I just let it do what it wants, does feel slightly different when very cold. Don't gorget to ignore your lower overall mpg when it's colder too lol.
    boston23 and Gamma11 like this.
  10. Dec 23, 2024 at 4:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lay outside overnight buck naked under a piece of sheet metal at -10 and I bet your motor will be loud when you try to move your arms too :D
    Gamma11[QUOTED], Rusty66 and Delta09 like this.
  11. Dec 23, 2024 at 4:27 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Ok, picturing that before 7:30am was not on my bingo card today o_O
  12. Dec 23, 2024 at 5:04 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Cars make strange sounds when ambient gets below 0 degrees F, especially on first start.
    Gamma11[QUOTED] likes this.
  13. Dec 23, 2024 at 7:14 AM
    Archimedes
    23 DCSB TRD OR MGM
    :anonymous:
    Gamma11 likes this.
  14. Dec 23, 2024 at 7:38 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I notice this too. Until the transmission gets above ~90F at least. Its most noticeable in and out of third gear, especially when slowing to a stop light and the vehicle downshifts.
    I'm not quite to 5k yet, but I'm going to do a drain and fill around 5k miles of the Toyota WS ATF in the remote chance its just a bit low on fluid from the factory.
  15. Dec 23, 2024 at 7:43 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    My 17 OR did this when it was cold as factory fill was a little over a quart low…..
  16. Dec 23, 2024 at 7:57 AM
    TurboDA6
    TurboDA6 Well-Known Member
    Every modern vehicle I have driven does this.
    It is intentional, the delayed shift allows higher revs which in turn creates higher ATF flows through the cooling system, which despite it being called "cooling" it usually allows the ATF to be warmed up in the ATF cooler which passes through the engine cooling loop. The engine warms up quicker than the AT does, so doing this also helps to utilize the engine to help warm the ATF.
    It's intentional, and usually so is a different shift feel, in some vehicles the shifts are firmer, and others the shifts may be sloppier. It's designed that way depending on what the engineers deem best.
    Vitamins likes this.
  17. Dec 25, 2024 at 8:37 AM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    My 2020 Tacoma, 2023 4Runner and currently my 2024 Tacoma have all done this.
  18. Dec 26, 2024 at 5:49 PM
    Sir Lounge Alot
    Sir Lounge Alot Member
    Lounge
    Tacoma 2024 ORP
    Had a similar situation and mentioned it to the dealer when in for the first inspection at six months. They "reset" the transmission (watched from a distance, they had a laptop plugged in the cab somewhere for about 20 minutes) and I thought it was bogus but since the cold shifts have been better. Could all be in my head but it seems improved.
  19. Dec 26, 2024 at 6:00 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Yeah ur trans fluid gonna be sludge at that temp on winter mornings of course it shifts weird.
    TurboDA6 likes this.
