Hesitate when trying to start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Annolino122, Nov 4, 2012.
  1. Nov 4, 2012 at 12:45 AM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    I just bought a 2013 Tacoma 4x4 off road, it only has 670 miles on it. Well when I go to start it, most the time it hesitates when I start it. It doesn't immediately crank over like you'd expect a new car would do.
    I asked the dealer, and they said they couldn't find any issue and it wasn't doing it enough. So has anyone had this issue and if so did you fix it?
  2. Nov 4, 2012 at 12:50 AM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    I personally wouldn't expect a new car to immediately crank and turn on. It's gotta go a few revolutions at least.
    I've driven 2 new cars in the past month from 2 manufacturers and they didn't start immediately.
  3. Nov 4, 2012 at 1:44 AM
    Beast Mode
    Beast Mode Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    My 12 does the same thing on cold starts in the morning. I suspect this is normal.
  4. Nov 4, 2012 at 1:50 AM
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    My 08 takes a while for the engine to fire when cold as well. My friend's 07 4Runner also. Seems like a common thing for these 4.0 v6's.
  5. Nov 4, 2012 at 8:56 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Are you saying it is turning over just not firing fast? If yes, try this, turn the key on (not start) and wait a couple of seconds for the electric fuel pump to come up to full pressure. Then continue turning the key to the start position and see if it makes a difference. My 05 V6 turns over a couple of revolutions before it starts also.
  6. Nov 4, 2012 at 9:06 AM
    Annolino122
    Evansville
    I live in a mtn town so the cold start thing may be the issue.
    And i also read somewhere about the fuel/air ratio with the computer so ill try waiting a few seconds
    If its normal, then ill just hope it always starts
  7. Nov 4, 2012 at 9:28 AM
    acdronin
    acdronin Well-Known Member
    Well, like a pitcher you need to commit more to your starting of the truck, have more confidence prior to turning the key, don't hesitate and the truck will sense this automatically.
    Kidding!
    I've had mine for 75k it's always taken a few revos to git 'er going, didn't seem like a problem to me.
  8. Nov 4, 2012 at 9:33 AM
    dwgltdco
    dwgltdco Live to Ride
    david
    Indian Hills
    08 tacoma trd offroad acess cab Silver
    trd intake
    My 08 has had this issue from when it was new. I took it in and the dealership has said this is normal with the 4.0l V6, especially at altitude. Even in bitter cold it eventually seems to start.
  9. Nov 5, 2012 at 10:07 AM
    Annolino122
    Evansville
    Awesome well that makes me a lot more comfortable. If its just a natural hesitation and there is nothing wrong then awesome. Thank you for the responses
  10. Nov 5, 2012 at 10:32 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    definitly normal my 05' did it and my cureent 11' does it everytime more in the cold then anything else.
  11. Nov 5, 2012 at 11:41 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    My '13 does the same thing. I have to keep the key in the start position for longer than any vehicle I've ever owned. That and the smog pump sound at turn off freaked me out at first but I got used to it.
    I'll try Failure2Comply's suggestion and see if it makes a difference.
  12. Nov 5, 2012 at 11:47 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    Try pumping Premium gas 92 octane. I've been switching from 87 to 92 because of the gas price change in my area. I noticed my truck start up quicker with the 92 and hesitant with the 87. It may just be me but doesnt hurt to try.
  13. Nov 5, 2012 at 12:05 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Here's the deal with the "long crank start". When you turn the key to the "On" position, listen to the truck. You'll hear the fuel pump whir/hum. Count to three and then crank the engine. Works every time.
    My 2012 gave me a few starting hesitations until I got in the habit of giving a 3-count before cranking, but now it always fires right up. Something to do with the injectors losing pressure after the truck sits for a while -- they need to be pumped back up.
    Good luck-
  14. Nov 6, 2012 at 8:07 AM
    Annolino122
    Evansville
    thank you ill try that
