Hesitation after spark plug change
Discussion in 'Technical Chat' started by rdvrs, Aug 10, 2021.
  1. Aug 10, 2021 at 3:27 PM
    rdvrs
    rdvrs [OP] Member
    Ron
    2008 Silver Access Tacoma, 4X4, 4.0,auto
    2008 Tacoma-208000 miles. Changed plugs, Wore out!! Put coil packs back on, took a drive an noticed a stuttering/ hesitation? Not all the time, once truck reached normal operating temp, seem to go away.
    Once every 2-3 second, then nothing for a minute or more? No CEL's- checked codes-nothing !
    Thought maybe connectors was not seat-no problem there! Took 30 miles round trip tonite, nothing to the store, then did it a couple times on the way back. Help?? TIA
  2. Aug 10, 2021 at 5:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What kind of plugs did you go with? OE Denso or NGK copper plugs are highly reccomended as some people have reported issues using platinum or iridium plugs in the 4.0.
    It's also possible there was a piece of trash or something between the electrodes of one of the new plugs and it worked it's way out.
  3. Aug 11, 2021 at 12:47 AM
    rdvrs
    rdvrs [OP] Member
    Ron
    OEM Denso plugs are what I put in. Checked all for proper gap before install. Could a coil be acting up? Will pull them out this weekend to check. Thanks
  4. Aug 11, 2021 at 4:39 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That is a possibility but until it throws a code unless you have a scanner that can read missfire data you won't know what cylinder to look at.
  5. Aug 11, 2021 at 5:50 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    A cracked plug will cause a miss and can get better when warm
    USMILRET likes this.
  6. Aug 11, 2021 at 3:21 PM
    rdvrs
    rdvrs [OP] Member
    Ron
    Dm93 an AODRN, thanks for the replies, will check for cracked plug first, buddy has reader that he says will read misfires, Will do this weekend.
  7. Aug 13, 2021 at 7:01 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    happened after last event of human intervention
    double check what U did
    6 gearT444E likes this.
  8. Nov 29, 2021 at 3:32 AM
    rdvrs
    rdvrs [OP] Member
    Ron
    Forgot to close this out. Was cracked insulator on the worst plug(#1) to get to. Runs like a champ now. Thanks
    USMILRET and ClassyTacos like this.
