hesitation during acceleration?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Dec 15, 2010.
  1. Dec 15, 2010 at 7:56 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So when i changed my plugs a while ago they where a little on the whiter side like the motor was running lean. I figured it was normal since its an EFI truck (2.7l). It always kinda bothered me, but now i am noticing it more an is getting pregressively worse. When the truck is warmed up not so much as when its cold, if i punch the pedal or even just slightly aggressive with it the truck will kind of bubble and stumble before catching up and reving out. My truck is a manual tranny and this happens without letting the clutch out (not under load) but happens under load as well. I have no idea other than maybe a fuel problem? fuel pump? idk it only happens on the low range and around highway speeds my pick up is terrible!!! i have to be in 4th gear around 4000-5000 RPM for any kinde of "passing speed" on the highway.
    I dont know any ideas??
    Thanks
    Wolfgang
  2. Dec 15, 2010 at 8:03 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Fuel filter stock? Seafoam, clean throttle body, maf sensor? All of those will make a big improvement on performance. If your concerned about it running lean you can do a fuel pressure check. If its a fuel problem check the fuel pressure first before you go out and buying parts. :thumbsup:
  3. Dec 15, 2010 at 8:26 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  4. Dec 15, 2010 at 8:32 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i also plan to replace the PCV vavle
  5. Dec 15, 2010 at 9:54 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Yea that is a good idea to replace them every so often, I need to replace mine and my fuel filter also. And Im not 100% sure on how to check the fuel pressure on these trucks, but google and youtube explain it well on other vehicles. :D
