Hesitation during low RPM acceleration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by huskcummerbund, Feb 20, 2022.
  1. Apr 17, 2023 at 2:22 PM
    #101
    txst
    txst Well-Known Member
    Wichita, KS
    2018 Tacoma Sport Access Cab, 6MT
    TSB0058-18, TRD Pro Grill
    I'm with you, julman99 and Firn. I even had a first gen Honda S2000 that had it's peak power at over 8000rpms. It was relatively gutless below 6000rpms, but it was silky smooth. In my 40+ years of driving, I have only owned two automatic vehicles, and have not experienced an engine that runs this weird. Either ours are anomalies, or others are not as sensitive to the issue. I believe it is the former, and just want to know what is causing it.
  2. Apr 18, 2023 at 6:36 AM
    #102
    txst
    Wichita, KS
    I should mention that one of the 6 speed trucks I test drove at the dealer, hesitated really bad. I chalked it up to being low on fuel and perhaps having a little moisture in the tank. When I drove the truck I bought, I didn't notice the hesitation at all initially. It seemed to pop up after 500 miles or so, but still isn't as bad as that first truck I drove. If I reset the learned values in the ECU, it seems to drive much better but then eventually reverts back to the weirdness.
  3. Apr 18, 2023 at 10:42 AM
    #103
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had been bs-ing with a friend from n.h. this morning that's buddies with a tech at a toyota dealership up there. I mentioned some of the weird stuff guys have claimed here. He told me there's a lot of truth to it, saying some tacoma's like any cars, or trucks, you can get one that runs strong, and others are a turd. They can't explain, or have found a reason yet, only that it happens.
  4. Apr 18, 2023 at 11:40 AM
    #104
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Looks like you have access to techstream or vf.
    Have you tried to datalog the issue?
  5. Apr 19, 2023 at 4:17 AM
    #105
    txst
    Wichita, KS
    Yes - I have VF Tuner. I haven't tried to datalog the issue, but it is on my list of things to do. I am by no means a pro at using that.
  6. Apr 19, 2023 at 6:54 AM
    #106
    txst
    Wichita, KS
    Is there a "How To" for data logging with VF Tuner or any suggestions as to what parameters to monitor in order to narrow down where the hesitation is coming from and how to flag time stamps in the data when a hesitation event happens?
  7. Apr 19, 2023 at 7:09 AM
    #107
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    vF is somewhat limited on what you can log, so here are some instructions with techstream, if you have it:
    https://www.tacomaworld.com/threads...ine-ecu-reflash.515734/page-165#post-17378987
    Here are some (old) vF Tuner logger instructions as well:
    https://www.tacomaworld.com/threads...n-turbo-systems.566390/page-513#post-24599155
  8. Apr 19, 2023 at 7:40 AM
    #108
    Firn
    Firn Well-Known Member
    White OR
    Has anyone who feels they have this issue checked to see if their spark plugs are tight?
    This is just such a weird issue and does not happen to all vehicles. With the multiple reports of blowby on lose plugs from the factory I have to wonder if its related.
    I only checked two of mine (the easy ones) which were fine, but want to get to checking all 6.
    That said,
    I have been doing a little bit of logging/monitoring and will say that I notice it more when under moderate load and fueling is maintaining its normal 13.8-14.1 AFR range, its hard to say but I feel like it gets a little better when the AFR starts to get more rich. At lower RPMs, say below 3000, it does take a fair bit of time at WOT before I see the AFR start to drop from the normal ~14. None of this is normal driving however as I don't ever got WOT in say 6th at 60 except to test this.
  9. Apr 19, 2023 at 7:45 AM
    #109
    txst
    Wichita, KS
    Thanks. Unfortunately, I don't have Techstream. I will try to log some data in the next few days.
  10. Apr 19, 2023 at 7:47 AM
    #110
    txst
    Wichita, KS
    Yes - I did check the torque on my spark plugs and all seemed fine. I was hoping it would be that easy!
    Firn[QUOTED] likes this.
  11. May 12, 2023 at 5:41 AM
    #111
    julman99
    julman99 Active Member
    Julio
    2022 White Tacoma TRD Offroad
    I found something and created a different thread: https://www.tacomaworld.com/threads/acis-tuning.801256/
    You may want to try disconnecting ACIS to confirm that is your issue, for me the engine feels buttery smooth without ACIS connected, however it looses a lot of top end power. Follow that thread for updates on the manner.
    Cheers!
  12. May 12, 2023 at 8:40 AM
    #112
    Firn
    White OR
    I ran without my acis for some time and still had the same issues. The severity was possibly reduced but the issue was still there. I did not notice a lack of top end however
  13. May 23, 2023 at 8:15 PM
    #113
    Firn
    White OR
  14. May 24, 2023 at 1:19 AM
    #114
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I cleaned my throttle body today with some elbow grease and it cleared up any stumbling i had under moderate load
    wayupnort likes this.
  15. May 24, 2023 at 1:53 AM
    #115
    wayupnort
    wayupnort Well-Known Member
    How many miles on your truck,and how dirty was it?
  16. May 24, 2023 at 6:28 AM
    #116
    joba27n
    Nolan
    Alberta
    114'000kms roughly and honestly not as bad as I expected since it's my first cleaning but took care of the stumble and increased my throttle response. Haven't done plugs yet nor checked plug torque ever
  17. May 24, 2023 at 6:37 AM
    #117
    z1288
    z1288 Active Member
    I have this same issue, I tried running a tank of premium fuel this week and it's almost resolved the issue.
