Hesitation exactly at 25 MPH and then again at 60 MPH Consistently
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ofrog, Nov 19, 2022.
  1. Nov 19, 2022 at 3:59 AM
    Ofrog
    Ofrog [OP] Member
    Florida
    01 PreRunner
    '01 v6 Tacoma 342,000. I keep getting a slight hesitation exactly at 25 MPH and then again at 60 MPH?! Not throwing a code. Fuel filter new, spark plugs new and properly gapped. Seafoamed it and cleaned the throttle plate and surfaces which was decarbonized. Changed the spark plug wires to new Npk's. When I changed the plugs noticed corrosion on one of the coils where the wire attaches. I cleaned it up but I am thinking that if corroded there probably inside corrosion. Coils are $175 to replace so before I attempt that...thoughts? Any ideas what else it might be? Seems to be less notice when I just gun it or after it heats up.
  2. Nov 19, 2022 at 4:20 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Where is engine rpm or throttle position? Test the throttle position sensor per manual and see if that's playing a part.
    Generally if the coil is bad, heat will make it worse.
  3. Nov 19, 2022 at 4:56 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Watch your rpm not your road speed .
    Auto or manual ??
    If an auto it might be a Transmission Issue.
