Hesitation/Miss when taking off
Discussion in '1st Gen. Tacomas (1995-2004)' started by Firefighter354, Jul 16, 2023.
  1. Jul 16, 2023 at 5:24 PM
    Firefighter354
    Firefighter354 [OP] Member
    1996 Green Tacoma 4x4 2.7L
    I have a 1996 Toyota Tacoma 2.7L 4wd A/T.
    Ive got an issue with hesitation/miss when taking of, using happens less than 2000 rpms. Once your going down the road, the truck does good. But horrible when starting to accelerate. Also getting a. P0172 code. Below is what i have changed or checked:
    Spark plugs and Wires
    Distributor
    Fuel injectors
    Vacuum Leaks(did change some houses that were bad)
    TPS ( Did use multimeter to check resistance)
    Checked VSV valve
    Cleaned throttle body
    Cleaned MAF
    Check IAT sensor
    Took fuel rail back off and made sure no leaks around the injector seals
    I may have done more, but can't think at the moment. Any other tips or tricks, I'd greatly appreciate it.
