Hesitation/no accelerator from start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trdintake, Jul 31, 2011.
  1. Jul 31, 2011 at 8:54 AM
    Trdintake
    Trdintake [OP] Member
    North Carolina
    08 Tacoma TRD 4WD
    TRD intake and exhause
    My '08 Tacoma TRD automatic with TRD intake and exhaust periodically hesitates from starting and even less frequently from a rolling 5mph and up start. There is no response from the accelerator until I let off the accelerator and press down again. I have spoken to other 2nd generation Tacoma owners who are experiencing a similar problem. Heading to dealer on Friday.
  2. Jul 31, 2011 at 9:28 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Sounds like something to do with the accellerator recall.... did you have it done recently?
  3. Jul 31, 2011 at 11:37 AM
    Trdintake
    North Carolina
    08 Tacoma TRD 4WD
    In for accelerator recall, and back, and still no remedy.
  4. Jul 31, 2011 at 11:40 AM
    brian
    Elizabeth City, NC
    The tacoma is a drive by wire system. The accellerator recall, from what I understand is an ECU reflash. From an electronics tech point of view, I'd start looking at a new gas pedal assembly. Sounds like the transmitter might be faulty.....
    I really have no idea though.
    :shrug:
  5. Jul 31, 2011 at 12:39 PM
    Trdintake
    North Carolina
    08 Tacoma TRD 4WD
    Thanks. Hope to know something Friday. Might be something related to wire harness.
  6. Jul 31, 2011 at 1:31 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I'd be looking more towards the drive system that open/closes the butterfly valve in the throttle body. If it's wearing it might start to lag.
  7. Jul 31, 2011 at 1:47 PM
    brian
    Elizabeth City, NC
    This could be very possible too.... they do work together as a pair. Since we've eliminated the ECU, its probably just down to these two. I would lean to the accelerator only because, in most cases, the part with the most human interaction is the part that breaks.
  8. Jul 31, 2011 at 1:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Id check for vacuum leaks around the intake, or a disconnected vacuum line. The accelerator has a tripple redundancy, and if any of the 3 systems go out of spec, a CEL iluminates.
  9. Jul 31, 2011 at 2:06 PM
    brian
    Elizabeth City, NC
    Is the throttle electronically controller or vacuum assisted?
  10. Jul 31, 2011 at 2:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its electronic, but a vacuum leak can cause similar issues.
  11. Aug 11, 2011 at 7:20 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Any word on what you found out??? Having similar issue!!!
  12. Aug 12, 2011 at 12:11 PM
    Trdintake
    North Carolina
    08 Tacoma TRD 4WD
    They could not find the source of the problem however they have opened a "tech case". Not sure what that means but hopefully it means if others are having similar problems other techs and factory folks will probe deeper into the problem.
  13. Aug 12, 2011 at 12:22 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
  14. Aug 14, 2011 at 7:03 AM
    huntark03
    Maumelle, AR
    I'm taking mine in this week...I'm sure they won't find it. That seems pretty normal for the dealership.
