Hesitation/sputter low throttle between 35-50mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oldylr, Nov 19, 2021.
  1. Nov 19, 2021 at 10:17 AM
    Oldylr
    Oldylr [OP] Active Member
    I get it from time to time giving it a little throttle for slight inclines or maintaining speed starting around 35-40mph. I replaced the plugs thinking that may be it but still does it off and on. Anyone else have a similar issue they have found a resolution for?
  2. Nov 19, 2021 at 10:21 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have a check engine light on? Have you scanned it for codes?
  3. Nov 19, 2021 at 10:45 AM
    Oldylr
    No check engine light so I have not checked for any codes yet.
  4. Nov 21, 2021 at 4:57 AM
    Oldylr
    Scanned for codes and nothing
  5. Dec 10, 2021 at 11:59 AM
    Oldylr
    Cleaned the throttle body today which by the looks of it was definitely needed. This did not fix my issue though. Seems to be getting a little worse. Any suggestions. Still no check engine light for anything. Can definitely feel it light bucking when it happens
  6. Dec 11, 2021 at 1:06 AM
    MemphisTaco08
    MemphisTaco08 Well-Known Member
    Brian
    Memphis, TN
    07 TRD-SPORT 4x4
    3/1 lift 33in tires Overland Yakima system with Yakima Skyrise HD2
    Yo, mine was doing the same a few years ago. It was really bad. I was told to replace the spark plugs and the wires. Replacing the plugs worked for me so I never did the wires. Might try that next.
  7. Dec 11, 2021 at 5:06 AM
    Oldylr
    Ours are coil on plug so there are no wires. Typically if a coil was bad it would throw a code so I could track it down to which one.
  8. Dec 11, 2021 at 6:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pull the coils out and look at the insulation for cracks or carbon tracking
    Plug in a scan tool and look at fuel trims while driving
    MemphisTaco08 likes this.
