Hesitation/Sputtering between 30 to 40 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by randy.click, Jan 25, 2017.
  1. 1
    1 vote(s)
    100.0%
  2. 2
    0 vote(s)
    0.0%
  1. Jan 25, 2017 at 8:49 AM
    randy.click
    randy.click [OP] Member
    Randy
    2007 Tacoma
    Wheels and tire
    2007 Tacoma 4.0l. Hesitation/Sputtering between 30 to 40 mph? Any thoughts?
  2. Jan 25, 2017 at 8:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Could be a multitude of things:
    • Plugs
    • wires/coil pack
    • fuel injectors
    Are you throwing codes?
  3. Jan 25, 2017 at 8:58 AM
    randy.click
    Randy
    2007 Tacoma
    Wheels and tire
    Not sure? The engine light has not come on?
  4. Jan 25, 2017 at 9:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did this just randomly come about? Have you had work done previously to the truck?
  5. Jan 25, 2017 at 9:08 AM
    randy.click
    Randy
    2007 Tacoma
    Wheels and tire
    No. Just oil change.
  6. Jan 25, 2017 at 9:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    When is the last time the plugs were changed?
  7. Jan 25, 2017 at 9:10 AM
    randy.click
    Randy
    2007 Tacoma
    Wheels and tire
    last summer. Hesitation is intermittent
  8. Jan 25, 2017 at 9:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    Without any codes it is hard to troubleshoot. So the engine is actually missing? Has the CEL flashed at all when this occurs?
    For now, I would just do a tune up with new plugs and cleaning the MAF sensor. You can also have it scanned to see if there is a code pending.
  9. Jan 25, 2017 at 9:18 AM
    randy.click
    Randy
    2007 Tacoma
    Wheels and tire
    Will do. Thanks.
  10. Jan 25, 2017 at 10:31 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    does this occur when on the flat and level constant speed - or on acceleration?
    FYI I had a car that did this when I was coming off an entrance ramp to the highway - as I accelerated through 30+mph to Highway speed it bogged. Turned out to be a bad fuel pump. (intermittent pressure when under demand).
  11. Aug 30, 2019 at 9:31 PM
    themarinepr
    themarinepr New Member
    Did you ever find out what the issue was? I own a 2011 Toyota Highlander and I am having the same issue.
  12. Aug 30, 2019 at 9:42 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    I'm leaning towards spark plugs
  13. Aug 30, 2019 at 9:49 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I vote fuel pump.
  14. Sep 19, 2019 at 10:11 AM
    Canufixit
    New England
    I assume you have ruled out the Gas / changed brand/grade?
