Hesitation when hard accelerating on a 2006 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteTacomaTRD, Sep 27, 2015.
  1. Jun 26, 2024 at 11:56 AM
    Japanese Ranger
    Japanese Ranger Member
    I haven’t tried the seafoam stuff yet. Can you clean the charcoal filter?
  2. Jun 26, 2024 at 12:31 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I removed mine a long time ago, as it was crumbling apart. it is plastic stamped in, be careful to only break free the tiny little rivet looking tabs.
    it is part of the emissions effort, but is pointless after so long and it does not look to be designed with replacement as a consideration.
    best way to clean chemicals out of charcoal is with boiling water. this is not really feasible in the intake.
    that 160k mi 18 year old activated carbon is not absorbing any emissions fumes anymore...
    seafoam is not a miracle, but i have used it on thousands of vehicles and it definitely can clean old fuel filters and lines, carbs, etc a little bit.
    just understand that seafoam or any cleaner can not do what mechanically cleaning will do. but for $10, it wont hurt and is worth trying.
    ridefreak likes this.
  3. Jun 27, 2024 at 8:39 AM
    Japanese Ranger
  4. Jun 27, 2024 at 8:43 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Replace dry rotted vacuum lines, too.
  5. Jul 20, 2024 at 7:09 PM
    Crippler25
    Crippler25 Well-Known Member
    I had a similar issue recently and it was the mass air flow sensor that went bad
  6. Jul 21, 2024 at 6:50 AM
    Japanese Ranger
    Thank you. I cleaned mine and didn’t see much of a difference. I think I will just replace it and see if that helps
