Hesitation???
Discussion in 'Technical Chat' started by Vander18, Jan 5, 2010.
  1. Jan 5, 2010 at 12:15 PM
    Vander18
    Vander18 [OP] Member
    Oregon
    2000 Tacoma SR5
    K&N Intake, Flowmaster 40 series, Fabtech 6" Lift, Toyo Mud Terrain Tires, Airbags, Aftermarket Stereo
    When I am driving and I get on the throttle at higher RPM's or going at higher speeds sometimes my truck seems to hesitate a little. Could it be fuel filter or spark plugs?
  2. Jan 5, 2010 at 12:17 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    hesitate how? like slower response to you getting on the gas more?
  3. Jan 5, 2010 at 12:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    It could be a number of things.
    Some basic things to do/check:
    - change fuel filter
    - change plugs
    - clean throttle body
    - seafoam
    - change air filter
  4. Jan 5, 2010 at 12:19 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    It could be a few things. Those you listed included. have you cleaned the throttle body at all? if so, have you ran seafoam through it?
  5. Jan 5, 2010 at 12:21 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    thats what i was thinkin.
  6. Jan 5, 2010 at 12:27 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    I am already on the gas when it does it...kind of feels like power loss for a second.
    I have not replace anything on it yet except O2 sensors.
  7. Jan 5, 2010 at 12:28 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    What is seafoam?
  8. Jan 5, 2010 at 12:29 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's a cleaner found at all auto parts stores. Search it on youtube.com once.
  9. Jan 5, 2010 at 12:30 PM
    Afwrestler1986
    Johnstown, NY
    Also, winter gas mixtures suck as well.
  10. Jan 5, 2010 at 12:30 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    might just need to give the engine a good inside cleaning with seafoam. how many miles on your 00'?
  11. Jan 5, 2010 at 12:32 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    Where do you put the seafoam at? I got 104,000 miles. I hardly drive it because I have a work truck for my job. So if it goes anywhere its just to the store
  12. Jan 5, 2010 at 12:33 PM
    Afwrestler1986
    Johnstown, NY
    You slowly pour 1/4-1/3 into your vacuum lines and the remainder into your gas tank.
  13. Jan 5, 2010 at 12:35 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    Alright I will try that and go from there....Thanks
  14. Jan 5, 2010 at 12:35 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Mine seems to do this while in D, shift down if you need to step on it.
  15. Jan 5, 2010 at 12:36 PM
    Afwrestler1986
    Johnstown, NY
    He has a manual, and is not drive by wire.
  16. Jan 5, 2010 at 12:37 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    Its a manual tranny and I am already at too high of an RPM to shift down.
  17. Jan 5, 2010 at 12:38 PM
    Afwrestler1986
    Johnstown, NY
    After putting it in the vacuum line, turn off your truck and let sit for 10-15 minutes, no more. Start the truck. It will smoke like a sumbitch......this is NORMAL. Just don't let the truck stall while pouring.
  18. Jan 5, 2010 at 12:39 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Didn't even look to see he had a manual, or first gen. Lol, nevermind my post.
  19. Jan 5, 2010 at 3:21 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    How long will it take for the seafoam to totally be gone?
  20. Jan 5, 2010 at 3:29 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I thought it was 1/3 vacuum lines, 1/3 crankcase and 1/3 gas tank?
    Was I mis-informed?
