Hesitation???
Discussion in 'Technical Chat' started by Vander18, Jan 5, 2010.
  1. Jan 5, 2010 at 3:50 PM
    Vander18
    Vander18 [OP] Member
    Oregon
    2000 Tacoma SR5
    K&N Intake, Flowmaster 40 series, Fabtech 6" Lift, Toyo Mud Terrain Tires, Airbags, Aftermarket Stereo
    What vacuum line do I put the seafoam in?
  2. Jan 5, 2010 at 4:09 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    actually where is it located is what I am asking. (vacuum line)
  3. Jan 5, 2010 at 4:17 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I have the same issue, I sea foamed my truck a month ago, and changed plugs back in August. I am thinking fuel filter or an injector. :eek:
  4. Jan 5, 2010 at 4:27 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I have always done it 1/3 to the lines rest to the tank.
    Drivers side all the way in the back of the engine bay you will see two hoses. Pull the top one and slowly pour, the suction will be more than enough to keep any from spilling if you go slow.
    My dad just had to replace an injector in his 5vz, I would hope your injector wouldn't be that bad. Good luck man.
  5. Jan 5, 2010 at 4:33 PM
    Vander18
    Oregon
    2000 Tacoma SR5
    okay I will give that a try and see what happens. I will also do the fuel filter cause it has never been done.
