Hestitation Issue - 2011 Tacoma w/TRD Supercharger
Discussion in 'Performance and Tuning' started by snowman72, Apr 28, 2013.
  1. May 12, 2013 at 7:52 PM
    #41
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Sub'd. Taking notes.
  2. May 23, 2013 at 4:23 PM
    #42
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Check the thing that the spark plug wires connect to, I think it's the distributer cap. If its not or a short/loose connection somewhere, it could be the computer. But the computers on vehicles rarely go bad.
  3. May 23, 2013 at 4:24 PM
    #43
    03f5sp
    Bill
    Wisconsin
    Is it possible that the computer erased the reflash?
  4. May 23, 2013 at 4:42 PM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No distributor cap. These use coil packs.
  5. May 24, 2013 at 9:48 AM
    #45
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    OP, had a similar issue with my Z06 which threw PO300. Checked injector harness for chaffing at the rear of the block, checked all chassis grounds, checked IAC, checked a bunch of other things. Ended up that I had blown out about 1" of my header gasket over the cylinder 1 primary causing the 02's to read unmetered air. Sorry if I missed it but are you experiencing any heavy fuel smell?
