Hey all you 255/85r16 people... got got some questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Aug 17, 2020.
  1. Aug 17, 2020 at 5:30 PM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I want to run my stock 16x6 rims and I have a 2 1/2" lift up front with @3" in back. How much rubbing on the UCA and inner fender wells can I expect?
    Thanks in advance
    Pat
  2. Aug 17, 2020 at 6:57 PM
    omegaman2
    omegaman2 Unknown Member
    2015 4WD DCSB
  3. Aug 18, 2020 at 5:15 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    I am 20 pages into the 243 and they are still arguing about wide versus narrow... I just want to know if they will rub with my set up (knowing that every truck is a bit different etc.) Seems like it should be a go, but hoping for some actual experience. Thanks for the post though...
  4. Aug 18, 2020 at 5:24 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    You should clear the UCA. How much you contact the liners is going to depend on your alignment more than anything.
  5. Aug 18, 2020 at 6:40 AM
    badger
    badger Well-Known Member
    07 SR5
    I cab mount chopped mine, and hammered the weld seam flat. UCA is OK. As stated, getting good camber means moving the wheel back. Better to just make room and not have to compromise good alignment. It's not hard.
  6. Aug 18, 2020 at 9:11 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    My truck has OME and AAL and I think I never hear nor see evidence of rubbing.
