Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Sep 12, 2023 at 3:49 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    and some good news! My flashing CEL (misfire on 4) turned out to be a dead fuel injector. All better now.
    Supply chain issues means I ended up with 1 new & 3 originals with 222k miles on them. Wait & see if that causes any running issues...
    - DOH!
    lynyrd3, TOMB, bucktales and 2 others like this.
  2. Sep 13, 2023 at 3:05 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy hump day.
  3. Sep 13, 2023 at 3:40 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning
    TOMB, MikefromCT, lynyrd3 and 2 others like this.
  4. Sep 13, 2023 at 3:43 AM
    Cativelense
    Nuno
    CT
    Thunder and lightning already, and starting to downpour.
    Lovely... Just lovely.
  5. Sep 13, 2023 at 3:44 AM
    Offbeattacos
    Offbeattacos Well-Known Member
    Kyle
    Wallingford, CT
    2020 TRD Sport MT cement
    At this rate I am never going to get my shed finished. I managed to get the ice/water and felt on last Friday before the rain, but this weather has not yet let me put shingles on.
  6. Sep 13, 2023 at 3:59 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The two adapters that I made.
  7. Sep 13, 2023 at 4:54 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :mad::rain:
  8. Sep 13, 2023 at 5:07 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Good morning folks
    Headed up to Portland Maine this morning, could be an interesting drive...
  9. Sep 13, 2023 at 5:37 AM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    Humpday! Today is supposed to be tremendous with the rain, but looking at the forecast we should get some reprieve after today. Everything being wet and damp all the time is really rather inconvenient.
    TOMB, Breakfast Taco and Cativelense like this.
  10. Sep 13, 2023 at 5:44 AM
    ChrisL72
    ChrisL72 Well-Known Member
    Westchester, NY
    95 v6, manual extra cab TRD
    None
    Good Morning
  11. Sep 13, 2023 at 6:07 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Almost have the ark completed.
  12. Sep 13, 2023 at 9:52 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Fail. The positive and negative wires are reversed. :confused:
    TOMB and Cativelense like this.
  13. Sep 13, 2023 at 12:39 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Fixed one. You can see what wires I switched.
  14. Sep 13, 2023 at 2:43 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Fixed the other adapter and installed the tweeters after work. Now it's time to change the mids because they sound like crap and the PASS side cuts in and out.
    I figured it out. The tweeters are plug and play for a 3rd gen, you have to make them work on a 2nd gen.
    TOMB, Cativelense and Breakfast Taco like this.
  15. Sep 13, 2023 at 2:50 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    :rofl:
  16. Sep 13, 2023 at 6:05 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    J-F-C I hit the high on the disgustingness scale today.
    Every fall I hose down the underside of my Tacoma.
    The following weekend I spray or go have sprayed Fluid Film or Wool wax.
    Well my Tundra e-friend from TN loaned me an Australian tool he has to rinse inside the frame.
    It arrived today, so I used it today.
    Rinse inside the frame, rinse outside the frame.
    This year I used a mini zip tie to encourage any small debris out of corner, pinch welds, rocker panel drains...
    Used my ungloved fingers to clear out debris in larger holes & to wipe down the grit from the frame.
    Of course all the water / debris / some Wool Wax - dripping, spraying, splashing, and pouring all over me as I'm slithering around beneath the truck.
    What was I thinking? LOL. What a freaking mess!
    A special thank you to @jasonct & the rest of you who spray our TW trucks.
    When I spray, I use cans of F.F. & it always seems to blow all over me, but that's nothing compared to guys spraying with a proper spray system.
    LOL- when I was done I walked up to the door to go in & clean up, realized I couldn't open the door. Even though I'd wiped off on the driveway with the hose, my hands were covered in W.W., they looked like I'd dunked them into a bucket of grease. Ended up sneaking in through the basement, washed my hands 3x with hand cleaner grit stuff before they were clean enough to use a disposable rag on them. and another. Then I washed them another 2 times with Palmolive. Presentable in a dirty way. LOL, maybe I should have thought of using disposable gloves.
    Any way - it's September & the truck is ready for it's winter underspray.
    Happy Wednesday all y'all.
  17. Sep 14, 2023 at 3:02 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Morning all. Swamp Azz advisories have been lifted by the NWS. :humble:
    Jrs13086[OP] and Cativelense like this.
  18. Sep 14, 2023 at 3:05 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Friday eve.
    lynyrd3 likes this.
  19. Sep 14, 2023 at 4:35 AM
    Offbeattacos
    Kyle
    Wallingford, CT
    That is reminding me to order all the goodies I need to do the fluid film spray down on our vehicles. I cannot wait to be able to garage the taco next year and help prevent most of the rust from developing.
  20. Sep 14, 2023 at 5:39 AM
    Jrs13086
    CT
    2023 TRD Sport LR
    Nothing yet
    Morning all. Finally looks like a break in humidity.
    Anyone have any experience with either the RSI SmartCap or the AluCab caps?
    Roody, Cativelense and Brownmatthall like this.
