Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Apr 4, 2024 at 12:35 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT. Happy Friday Eve!
    I did not start to wire my compressor. The weather sucked when I left work so I decided to just go home. I'll be bringing the truck to work on Saturday. If I get out early today or tomorrow, I'll start it then.
    TOMB, lynyrd3, CTSpruceMica and 2 others like this.
  2. Apr 4, 2024 at 3:05 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    happy Friday eve.
    TOMB, lynyrd3 and CTSpruceMica like this.
  3. Apr 4, 2024 at 3:39 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Freezing rain, WTF?
    lynyrd3 and Cativelense like this.
  4. Apr 4, 2024 at 4:09 AM
    Cativelense
    Nuno
    CT
    It's snowing down here now... grass is covered, but the roads just looks wet.
  5. Apr 4, 2024 at 4:28 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :hattip:
    Wet sloppy snow here
    TOMB, CTSpruceMica and Cativelense like this.
  6. Apr 4, 2024 at 4:28 AM
    Cativelense
    Nuno
    CT
    Nothing like starting off the day by trying to remote log into work so you can actually work, and the program we use to do that is down.
    FML
    TOMB and lynyrd3 like this.
  7. Apr 4, 2024 at 4:28 AM
    lynyrd3
    Bill
  8. Apr 4, 2024 at 4:42 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Annnnd it's snowing.
    Take off the Blizzaks he said. I won't need those he said.
  9. Apr 4, 2024 at 7:46 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    You jinxed us by pulling the snow tires off. Thanx dennis..
    lynyrd3, TOMB, Roody and 1 other person like this.
  10. Apr 4, 2024 at 8:03 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    lynyrd3, TOMB and Cativelense like this.
  11. Apr 4, 2024 at 1:26 PM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    Howdy all....Thankfully it looks like the sun is starting to poke through.
    Pulled the trigger today on the Decked drawer system. I am still hemming and hawing over a canopy or rack. I am leaning towards a rack and will probably go the Leitner route. It is by far the most costly but from what I have read and seen the most well built and I like that its completely customizable. Ill end up spending the same-ish money in the end regardless of the route I go but at least with the rack I can do it in palatable increments.
  12. Apr 4, 2024 at 4:54 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    I had the front brakes serviced.
    New Rotors, Pads, Shims, springs, Pins. I also did the double spring mod to make the pads retract in a more accurate manner.
    I would say that i got my monies worth from the old Pads as they were worn equally but one as warn to the metal so its wasn't going to be another couple of weeks and all would be metal to metal.
    As I mentioned earlier, I went with original Toyota parts from Middletown Toyota in wait for it, Middletown Ct
    New parts "Yea"
    TOMB
  13. Apr 5, 2024 at 12:54 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning everyone. Friday yet again.
    Was waiting on parts for that GX460. Trans cooler hoses were leaking. Transmission was 3 qts. low. :eek:
    We were not able to leave early the last two days so it looks like I'll be working on the truck this Saturday.
  14. Apr 5, 2024 at 3:04 AM
    lynyrd3
    Bill
  15. Apr 5, 2024 at 3:06 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Friday.
    TOMB, CTSpruceMica and lynyrd3 like this.
  16. Apr 5, 2024 at 7:35 AM
    Steve0ct
    Steve0ct Well-Known Member
    CT
    2017 TRD Off-Road DCSB White
    Anyone else have there house/building shake a few minutes ago? Wild!
  17. Apr 5, 2024 at 7:38 AM
    Cativelense
    Nuno
    CT
    Yeah... I was outside going for my daily power walk so I didn't notice anything.
    But supposedly there was an earth quake, 4.8 magnitude somewhere in NJ, that we all felt around here.
  18. Apr 5, 2024 at 7:38 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    definitely just had an earthquake
    felt it on long island
  19. Apr 5, 2024 at 7:38 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Earthquake, 4.8 magnitude from NJ. Felt my house shake in Collinsville at 10:29. Local facebook group for the town is going nuts about it.
  20. Apr 5, 2024 at 7:39 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Oh yeah, shook the house pretty good.
    Cativelense and CTSpruceMica like this.
