Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Apr 28, 2024 at 3:49 AM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    Thank you thank you
    Cativelense likes this.
  2. Apr 28, 2024 at 3:51 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    How did you run the power wire from the solar panel? Were you able to find the channel we spoke about?
  3. Apr 28, 2024 at 3:58 AM
    Jrs13086
    CT
    2023 TRD Sport LR
    Nothing yet
    I found this:
    Rubber Bond Cord Cover Floor Cable Protector - Strong Self Adhesive Floor Cord Covers for Wires - Low Profile Extension Cord Covers for Floor & Wall - Black - Thick Cord - 6 Feet https://www.amazon.com/dp/B0B3SM614J
    I bought the good industrial 3m dbl stick tape you mentioned. By the time I was wrapping up last night it has justtttt started to drizzle, plus it was also rather "Dewey" out and so I opted not to use dbl stick tape on a wet surface lol. After work today I will clean the cab and stick this on. I ran the ground wire down past the grommet and under the truck. There was a grounding point on the frame I used.
    I will make the finishing touches today and tidy up with zip ties etc.
  4. Apr 28, 2024 at 6:01 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Sunday.
    Kiddo has another game today. Had one yesterday and got smacked in the mouth. Hoping for a better result today.
    TOMB, Jrs13086[OP] and CTSpruceMica like this.
  5. Apr 28, 2024 at 12:14 PM
    Cativelense
    Nuno
    CT
    Lost 2-0 today.
    They have kids reffing these games, and they're afraid to make calls, and when they do they are wrong. The kids that play are never gonna learn to play the game the right way because of these kid refs.
    It's really bad.
    TOMB and Jrs13086[OP] like this.
  6. Apr 28, 2024 at 1:41 PM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    This guy?
    Cativelense[QUOTED] likes this.
  7. Apr 28, 2024 at 2:13 PM
    Cativelense
    Nuno
    CT
    Might as well have been.
    And believe me, I don't like to criticize them because 1) they're kids, and 2) it's a hard job to do.
    But if you're not up for the task, don't know the rules and/or don't enforce them then there's no point being there. You're not doing yourself a favor, and you're not doing the kids a favor either because then they're not taught the right rules from the beginning.
  8. Apr 28, 2024 at 6:12 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    I need to use that same grommet on the back wall of the Ridgeline. For the tailgate backup camera handle.
    To get to that pass through on the Ridgeline:
    remove cap, remove sidewall cap, remove bed sidewall, remove panel above rear window, remove bedwall between bed & cab, run wires to pass through.
    On the interior - remove rear headrests, remove below rear window trim panel, remove back seats (bottoms & backs), remove seat belts, remove in cab back wall panel, remove something I've forgotten on the floor, remove c-pillar cover, remove rear door sill, lift carpet. Run wire through hole/grommet in rear wall of cab/front wall of bed.
    just going to be annoying. Congrat's on your success.
    CTSpruceMica and Cativelense like this.
  9. Apr 29, 2024 at 3:04 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Monday.
    TOMB and CTSpruceMica like this.
  10. Apr 29, 2024 at 3:22 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    :wave:
    Took a ride last night after it got dark to get dinner. Now everything lights up like it's supposed to. :thumbsup:
    There are two switches that look dim on one side. Maybe I'll swap in another LED to see if maybe I got a bad one in there.
    I still need to put a LED in the PRNDL. I'll have to order some on Amazon.
  11. Apr 29, 2024 at 3:37 AM
    Offbeattacos
    Offbeattacos Well-Known Member
    Kyle
    Wallingford, CT
    2020 TRD Sport MT cement
    Clearly I have been ignoring this build! So you are putting all of your house lighting and charge controller stuff in that cubbie behind the rear seats? I am definitely excited to do something like this in my future, when I finally get around to building or buying a camper that can sit in the bed.
    TOMB, Cativelense and CTSpruceMica like this.
  12. Apr 29, 2024 at 3:50 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Happy Monday...only one this week
  13. Apr 29, 2024 at 4:07 AM
    Jrs13086
    CT
    2023 TRD Sport LR
    Nothing yet
    Yeah so basically my plan is I have almost everything run off of that secondary battery. We will see how the rest of the week goes but if it all goes to plan, I'll order the RSI Smartcap. Once I have that, I will run one more power wire to the bed on the passenger side as there's another grommet there. I already have the fuse block and so I will build a little "power center" where all of my other lights (camp lights, rock lights, rear facing lights, etc), fridge, water tank, compressor, etc will get wired to. Initial plans involve a molle panel and will get placed somewhere in the back of the bed - closest to the cab. I'm also kicking around the idea of an inverter as well which would get mounted on that same molle panel. Ideally I would like to not have anything else with the exception of an upgraded stereo (components and an amp) physically wired to the second battery in that cubby.
  14. Apr 29, 2024 at 4:37 AM
    Offbeattacos
    Kyle
    Wallingford, CT
    Oh that sounds like so much fun! If you need anything designed and 3D printed, let me know and I can try to help out, unless you can already do those kinds of things yourself :D
    I've been using the taco as a legit truck so much recently with getting dirt, compost, stone, etc. I'd love to have a fiberglass style cap one day over the bed, but only if I can get a way for it to go on and off easily
  15. Apr 29, 2024 at 4:43 AM
    Jrs13086
    CT
    2023 TRD Sport LR
    Nothing yet
    Cheers man thanks!!! I understand it, but just dont have the time or money to invest in a printer etc. Plus I already have an expensive hobby lol. With the cap, as long as you dont have an infinite amount of crap actually attached to it, they come off rather easily. My situation would not fall into the rather easily category as I will have wires and stuff mounted everywhere. Taking that apart would be a nightmare. Plus with in reason, I can still toss a fair amount of stuff in the bed with the cap on. Add to that the decked drawer system can support 1000 lbs.
  16. Apr 29, 2024 at 10:28 AM
    scofflaw
    scofflaw Well-Known Member
    Finally crossed BAR Pizza off the list yesterday, it always seems to be closed or packed when we've tried to go before. Worth the wait, both the beer and pizza were solid. Some of the best pizza I've had in NH and I only had one beer so I think that's an objective assessment. Incredible weather yesterday too, hope it continues into May, fingers crossed.
    Planning to try Reverie in Newtown on Friday, although if it seems less than great we may quickly shift over to Newsylum.
  17. Apr 29, 2024 at 11:05 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
  18. Apr 29, 2024 at 4:29 PM
    Cativelense
    Nuno
    CT
    Finally mowed my lawn for the first time this season, after work.
  19. Apr 30, 2024 at 3:03 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Tuesday.
  20. Apr 30, 2024 at 3:13 AM
    Cativelense
    Nuno
    CT
    Have the follow up appointment this morning, to find out the results from the MRI.
    Hoping to get some answers.
