Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jan 11, 2025 at 2:24 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning. Happy Saturday.
    While I was waiting for Amazon to show up, I looked through the anytime camera kit as I read the install guide.
    I found a nice spot to mount the switching relay (top of the radio, screw that holds the bezel) along with a way to run the wires to the switch. I have to see if the radio will still fit with the relay where I have it.
    If not, I'll have to find a spot in the truck for the relay.
    TOMB, Cativelense and SilverBulletII like this.
  2. Jan 11, 2025 at 5:37 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning
    lynyrd3, TOMB and Cativelense like this.
  3. Jan 11, 2025 at 7:35 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Saturday.
    Snow was practically dust, so cleaned it with the leaf blower. Then got carried away, and cleaned 4 of my neighbors driveways as well.
    lynyrd3, AllTacosFloat and TOMB like this.
  4. Jan 11, 2025 at 8:55 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    One step forward and two steps back.
    The antenna wire I bought doesn’t fit the bracket. Have to order one from Midland.
    At least I have the Auxbeam mounted.
    I’ll see about where I want to run the wire into the cab and check out wiring the front camera.
    I did finish putting primer on the sliders.
  5. Jan 11, 2025 at 10:54 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Thanks to @AllTacosFloat I was able to run the wire for the Auxbeam without too much trouble (he gave ma a can of silicone spray).
  6. Jan 11, 2025 at 12:44 PM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    Happy Saturday all.....Nice little dusting today.
    TOMB, Cativelense and lynyrd3 like this.
  7. Jan 11, 2025 at 12:50 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That’s what we got. It’s just about melted.
  8. Jan 11, 2025 at 12:54 PM
    Jrs13086
    CT
    2023 TRD Sport LR
    Nothing yet
    Pretty much, was just about 32F this morning. Was heavy wet snow. The roads cleared up pretty quickly as the day went on.
  9. Jan 11, 2025 at 1:13 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Found a nice spot to mount the front camera. Brought some tools home, now I have to remove the grille and drill the hole.
  10. Jan 11, 2025 at 3:55 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Ran the control wire for the Auxbeam through the large grommet on the drivers side of the firewall. I'll need to add a couple more wires (outside temp display, ACC for Auxbeam and the fog light relay wire.
    I'll run the wire for the front camera where I originally had the GMRS antenna ran (small hole at the bottom of the booster). The switching relay won't fit, I'll have to find another spot for that. It hits the top of the radio surround.
    The GMRS antenna will be run through the passenger side grommet.
    Looks nice enough tomorrow to get some stuff done. :thumbsup:
    lynyrd3, CTSpruceMica, TOMB and 3 others like this.
  11. Jan 11, 2025 at 5:50 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  12. Jan 11, 2025 at 6:30 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    But don't worry because we will have a mod day at my house waaaaaaay before that.
    lynyrd3, MikefromCT, TOMB and 3 others like this.
  13. Jan 12, 2025 at 1:22 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT.
    A little :pccoffee: then some :washing: and then I'll take my grille off and drill the hole for the front camera. There is a small piece of plastic that I will have to clearance for the nut. Brought my Dremel home along with some other tools.
    I also think I developed a slight clunk in the L/F. Upper control arm bushings?
    quote-if-you-want-to-change-the-world-start-off-by-making-your-bed-william-h-mcraven-74-80-49.jpg
  14. Jan 12, 2025 at 5:28 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Sunday.
    lynyrd3 and TOMB like this.
  15. Jan 12, 2025 at 5:31 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning
  16. Jan 12, 2025 at 3:04 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Guess who forgot to bring their drill home?
    I did not drill the hole in the grille for the camera. I did do some Spring cleaning. :thumbsup:
    lynyrd3 and Cativelense like this.
  17. Jan 13, 2025 at 2:22 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT.
    Seeing that I didn't have my drill and couldn't mod my grille like I wanted, I gathered all my airsoft gear and listed it for sale on an app on my phone.
    Let's hope all of it quickly sells so I can buy a front bumper and winch.
    lynyrd3, CTSpruceMica and Cativelense like this.
  18. Jan 13, 2025 at 3:55 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Monday.
    lynyrd3 and CTSpruceMica like this.
  19. Jan 13, 2025 at 4:08 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    MONDAY MOTIVATION
    Annual review time? Tell your boss to stop living in the past.
  20. Jan 13, 2025 at 4:52 AM
    Jrs13086
    CT
    2023 TRD Sport LR
    Nothing yet
    Happy Monday all.
