Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jun 2, 2025 at 4:18 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Good morning CT
  2. Jun 2, 2025 at 4:20 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Better load up on energy drinks!
    TOMB likes this.
  3. Jun 2, 2025 at 4:30 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Pot of coffee locked and loaded
  4. Jun 2, 2025 at 5:09 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You’re able to make it from aluminum?
    Cativelense likes this.
  5. Jun 2, 2025 at 5:17 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Yep, made this one for @InCogNeatOh Parts, flatbed fenders, and a tailgate for my flatbed(this came out a little wonky but I was out of material)
  6. Jun 2, 2025 at 5:50 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning
  7. Jun 2, 2025 at 10:03 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Mounted the remote start module using the bracket I made. It’s a prototype. It uses the nut from the e-brake. @TacoTuesday603 is going to make me one out of aluminum.
    crashngiggles, Cativelense and TOMB like this.
  8. Jun 2, 2025 at 10:05 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Is that floppy? ABS is likely to sag in the temps that the cab will get up to in the summer
  9. Jun 2, 2025 at 10:15 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Great seeing you Dennis and Karen. Thank you for the hospitality.
    And here we go.
  10. Jun 2, 2025 at 10:26 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    It shakes quite a bit. I’ll lay under the dash later and see what I can do. Aluminum will be stronger.
  11. Jun 2, 2025 at 10:48 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can also see the small cut I had to make in the tab because of the metal e-brake bracket.
  12. Jun 2, 2025 at 10:51 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I dont see it but just include everything you need in your drawing to me. Everything will be well within 0.050" and 1.5 degree on the part I make
    edit 0.5 degree not 1.5
    Cativelense and CTSpruceMica like this.
  13. Jun 2, 2025 at 11:14 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
  14. Jun 2, 2025 at 2:41 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    That looks great Mike!! Nice early BD present for youself!
  15. Jun 3, 2025 at 2:52 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy hump day.
    TOMB and Roody like this.
  16. Jun 3, 2025 at 3:33 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning. Day off for me. Going to Toyota to order a couple things.
    Happy birthday @MikefromCT
    Finally fixed the GMC that I was looking at for a friend. The accelerator pedal was bad, there was a broken wire going to the pedal and the connector for the throttle body needed to be replaced. How can so many issues happen in one system?
    MikefromCT and Cativelense like this.
  17. Jun 3, 2025 at 3:45 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
  18. Jun 3, 2025 at 3:46 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Check your calendar
  19. Jun 3, 2025 at 3:57 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
  20. Jun 3, 2025 at 4:50 AM
    Cativelense
    Nuno
    CT
    I'm all out of wack.
    LOL
