Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Dec 12, 2019 at 7:26 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    I'm just messing with you,
    It's your truck and you like it the way you like it:rofl:
    I was serious on the car wash though.
    CurtisLoew and Cativelense like this.
  2. Dec 12, 2019 at 10:58 AM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    Cruised a gravel road in Pachaug State Forest. Beautiful.
    TOMB, WunderSlug, lynyrd3 and 5 others like this.
  3. Dec 13, 2019 at 2:50 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone! Happy Friday.
    Using up some more vacation time todah, and taking a half day to run some errands in the afternoon.
    Skierrichy, CT18Tacoma, TOMB and 5 others like this.
  4. Dec 13, 2019 at 2:50 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Mornin' all
    Skierrichy, CT18Tacoma, TOMB and 4 others like this.
  5. Dec 13, 2019 at 4:21 AM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    morning all. it is morning - right? 'cause it's kinda midnight black out my window when I looked a little bit ago......
  6. Dec 13, 2019 at 4:30 AM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Nothing has no scent. It's still there on some microscopic level.
    Either you still have oil on a hard surface, for hard surfaces the citrus products sprayed, let soak, then absorb away with clean rags. Rubbing just tends to smear the issue - blot for the win.
    Or if you have soft surfaces (bed liner/ cap with cloth lining, etc) there are microscopic quantities that have gotten airborne & landed on the soft surfaces. For soft surfaces, something like Febreeze or Lysol sprayed about, then vacuum.
    …& think microscopic.
    (I'm more current on my housekeeping than my human resources law).
    Good luck - let us know what ended up working in your case.
    TOMB, Skierrichy and Cativelense like this.
  7. Dec 13, 2019 at 5:01 AM
    lynyrd3
    Bill
    East Central Upstate NY
  8. Dec 13, 2019 at 6:13 AM
    CurtisLoew
    CurtisLoew Well-Known Member
    2018 TRDPRO
  9. Dec 13, 2019 at 7:57 AM
    WunderSlug
    WunderSlug Well-Known Member
    '17 QS DCLB TRD OR
    morning all....
  10. Dec 13, 2019 at 8:26 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Getting frame inspection done at Stephens Toyota right now.
    lynyrd3, Breakfast Taco, TOMB and 5 others like this.
  11. Dec 13, 2019 at 8:32 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Sometimes it is nice to be able to hear my truck's exhaust from outside when it starts and the mechanic pulls it into the garage.
    Damm shes sounds and looks good. :devil::D
  12. Dec 13, 2019 at 9:52 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    I lost my master key and im running with my valet key right now. I already ordered some new keys online and they should be here soon. I asked Stephens Toyota how much they would charge to reprogram the keys, they said it would be a minimum of 1 hour labor most likely 1.5hr @ $129hr. Since they have to reprogram them all.
    It would cost me close to $170 just to have them program keys that I'm bringing them.
    That's crazy.
  13. Dec 13, 2019 at 10:57 AM
    WunderSlug
    '17 QS DCLB TRD OR
    Yes. Yes it is. But since you need a master key to reprogram a new key yourself, they've got you over a barrel. Unless someone figured out a way to do it with a valet key, but I don't think anyone has. I can ask my locksmith buddy.
    Cativelense likes this.
  14. Dec 13, 2019 at 12:08 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    That would be awesome if you could ask him. That was going to be by next person to ask. I don't know if it different Toyota dealership would charge less or not LOL.
  15. Dec 13, 2019 at 4:34 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'd reckon it isn't going to change dealer to dealer, that's the same quote we got for my wife's 2014 Rav4
  16. Dec 13, 2019 at 4:38 PM
    WunderSlug
    '17 QS DCLB TRD OR
    Response from my locksmith friend:
    As far as I know, the valet keys and master keys are the same cut and same chip but at the time of programming the gray head valet key is assigned in the truck computer as a non-master key. So, I think, it could be reassigned in the computer BUT Toyota does not allow self programming so a programmer must be connected to the OBD on the truck. Also, without a master key I think Toyota implements a 10 minute lockout during programming.
    In short, YES a valet key can be reassigned, but not without a dealers help, or a locksmith with an odb programmer. Which is rare apparently...
  17. Dec 13, 2019 at 6:32 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Thanks for the info.
  18. Dec 14, 2019 at 6:21 AM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    good rainy morning. Going to be a bumper crop of spring flowers? so much rain - which isn't snow :--)
    TOMB, Cativelense and CurtisLoew like this.
  19. Dec 14, 2019 at 6:25 AM
    lynyrd3
    Bill
  20. Dec 14, 2019 at 7:16 AM
    CurtisLoew
    2018 TRDPRO
    Skierrichy, Bridge4 and Cativelense like this.
