Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Apr 22, 2021 at 5:45 AM
    SamSpade
    SamSpade Well-Known Member
    Rob
    Riverside, CT
    White ‘01 4x4 2.7L 5M
    Morning, guys.
    That’s a beautiful sight.
  2. Apr 22, 2021 at 6:09 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Thank you. It will be interesting to look under the truck and see shiny stuff lol.
    36f and snowing here in bristol.
  3. Apr 22, 2021 at 6:22 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Very jealous of those new uca’s and hardware. My hardware for the lowers are seized, and ive been debating oem vs aftermarket for the better half of a year now (dirt king w ball joint). Leaning towards oem’s due to cost at this point.
    Im going in for an alignment Friday to make sure everything is decent for the trip; especially after tossing in the spacer last weekend to correct the lean.
    Might look to pull the trigger on the lowers and new hardware soon.
  4. Apr 22, 2021 at 6:30 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Not doing UCA just replacing the LCA instead of replacing just the bushings. When I got my last alignment is when they told me the cam adjusters were seized up. For the LCA there's no reason not to use the OEM.
    I got all of my OEM hardware from https://parts.mcgeorgetoyota.com/ at wholesale cost. LCA $260 each instead of $400 each. Give them your vin# and they built a cart for me to replace everything that was getting unbolted.
  5. Apr 22, 2021 at 6:32 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    I meant lcas; my b. Havent had enough coffee yet. Little one had me up early. Im shot.
    Did my ucas last year; the lcas are original with 123k; seized cams.
  6. Apr 22, 2021 at 6:34 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Also, there are some advantages for the dirt kings over oem. Beefier for wheeling; greasable ball joint; etc. Its just not enough for me to justify at the moment. Theres a big cost difference between the two.
  7. Apr 22, 2021 at 7:49 AM
    TRD_Taco_No.2
    TRD_Taco_No.2 Member
    Rock
    CT
    2014 DCOR Super White
    Snow squalls and sunshine...I would show on the Taco but doesn't work well with super white
  8. Apr 22, 2021 at 9:52 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    The same thing happened to me last summer when both of my lower control arms and bolts were seized. I looked into aftermarket bolts and I have come to the determination that aftermarket bolts were absolute crap and went with OEM bolts for the replacements. When it came down to my lower control arms, I had Three options. I could either Buy new lower control arms that were OEM which were going to cost about $1000, pull out the bushings and replace them with energy suspension bushings but that route would've been a complete pain in the ass, or go with Dirt King lower control arms that had greasable zerk fittings. I went with the last option Mainly because We live in New England and uniball Ball joints were out of the question. I absolutely love my Dirk King lowers and I made sure to absolutely grease the crap out of my OEM bolts. It is nice to because when I grease my bolts, I also release the tension on my lower control arm bolts to grease the bushings and turn them to make sure that they don't seize up anymore.
  9. Apr 22, 2021 at 9:58 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    I really want the dks, mainly for the point you make about the greasable ball joint, but if I can get oems at 260 a piece...
  10. Apr 22, 2021 at 12:52 PM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Rage Against The Machine never said what device it was they were pissed at.
    After my morning I'm guessing it was a Canon wireless printer.
  11. Apr 22, 2021 at 1:10 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Its always the printer
    Skierrichy, Bridge4, lynyrd3 and 3 others like this.
  12. Apr 22, 2021 at 1:24 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
  13. Apr 22, 2021 at 1:33 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Wife received her 2nd shot today , that will help her anxiety and stop worrying about getting the covid .
    Yea
    TOMB
  14. Apr 22, 2021 at 1:41 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Afternoon Connecticut :hattip:
  15. Apr 22, 2021 at 1:42 PM
    lynyrd3
    Bill
  16. Apr 22, 2021 at 1:45 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Happy Earth Day
    :humble:
  17. Apr 22, 2021 at 2:28 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Smoking ribs bucktales?
  18. Apr 22, 2021 at 3:32 PM
    Brownmatthall
    2016 TRD OR DCSB
    2 freaking cats in this house and this is what I come home to?
  19. Apr 22, 2021 at 3:58 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
  20. Apr 22, 2021 at 5:51 PM
    lynyrd3
    Bill
