Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Dec 16, 2021 at 3:52 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    53° at 5:00 am on 12/16?
  2. Dec 16, 2021 at 4:32 AM
    Johnny balls
    Johnny balls STILL NOT AN ADULT
    Jay
    CT
    2016 inferno dcsb
    Big sticker guy Lots of wasted money
    agreed
    Cativelense likes this.
  3. Dec 16, 2021 at 5:59 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    And then snow on Saturday :confused:
  4. Dec 16, 2021 at 5:58 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    I liked this so I could unlike it. :)
  5. Dec 16, 2021 at 8:26 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I have had a Bakflip G2 tri-fold for 10 years on my 2nd gen in CT and it has been AMAZING. I am in the process of replacing some of the rubber seals and stuff that have started to wear and tear from constant usage. I Had to Liquid Nails (fuze it) 1 of the crossmembers back into place since the factory adhesive had started to sag over the summer heat. I went ahead and Fuzed the other crossmember along the edges and some of the areas that it was starting to gap also. I purchased a couple of parts from BakFlip direct to replace the other worn parts.
    BAKFLIP CAB BUMPER KIT (2)- $9.96 replacing the protective bumpers that are on each of the 3 sections. They are starting to tear
    BAKFLIP ELEVATOR BOLT KIT-$9.98 -starting to rust
    BAKFLIP DRAIN TUBES (1)-$6.98 - many season changes are making them harden and starting to clog.
    BAKFLIP DRAIN CAPS (1) -$5.98- they seem to be ok, but im doing it all anyways so $5 is not bad.
    BAKFLIP PROP ROD (2)-$23.96- same as before... preventative part of project.
    BAKFLIP/RX2 FLAT RAIL SEAL- $15.98 Runs down the sides of the truck bed it takes the weight of the cover. It is fully compressed in some areas and tearing in others.
    Order Total: $77.47
    Totally worth the initial $850+ that they cost 11 years ago
  6. Dec 17, 2021 at 3:15 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Morning CT.
    I get out early today, then a work Christmas party and new lower control arms tomorrow.
  7. Dec 17, 2021 at 3:29 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Friday at last.
  8. Dec 17, 2021 at 4:01 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut
  9. Dec 17, 2021 at 4:02 AM
    lynyrd3
    Bill
    2-4” snow forecast here for tomorrow
    TOMB, MikefromCT, Red Alert and 2 others like this.
  10. Dec 17, 2021 at 5:00 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Big red is ready for the snow. All fixed up after it grenaded oil cooler lines. Mice got into the harness, and it needed a new starter and battery. Fun little bill.
    lynyrd3, CTSpruceMica, TOMB and 3 others like this.
  11. Dec 17, 2021 at 5:26 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Too bad the warmth won't continue into Saturday. Snow, rain, wintry mix, high 35.
    lynyrd3, TOMB and Cativelense like this.
  12. Dec 17, 2021 at 6:28 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Hopefully we can have the door shut as we are working. If not, I could do it another time.
  13. Dec 17, 2021 at 7:26 AM
    KeithB
    Keith
    Cheshire, CT
    No, door can be closed and maybe I'll get a little heater going.
    TOMB, Cativelense and super_white like this.
  14. Dec 17, 2021 at 7:26 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That’s what I like to hear. Did the noise come back?
  15. Dec 17, 2021 at 10:48 AM
    KeithB
    Keith
    Cheshire, CT
    Nope, still good. Fluke? :notsure::fingerscrossed:
  16. Dec 17, 2021 at 10:56 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    @tattooedsnake
    I have the same type of backflip G2 that you have mine's been great since 2013 seals are still in good shape but the slide locks that you undo from the Inside are starting to fail I tried to take one apart to replace the attachment but it seems like I have to disassemble the whole back Leaf to do it that would be an ongoing project in the spring.
    TOMB
  17. Dec 17, 2021 at 11:46 AM
    Brownmatthall
    2016 TRD OR DCSB
    Wife's camry has a gnarly exhaust leak so I bought her a new gasket thinking it'd be a simple swap...nuts were gone and the bolts were rusted on. Had to grind both off and drill one out. Got it done but the pipe is corroded to shit so who knows how long it'll last lol, hope it waits til after winter :fingerscrossed:
  18. Dec 17, 2021 at 3:15 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    How old is it?
  19. Dec 17, 2021 at 4:18 PM
    Brownmatthall
    2016 TRD OR DCSB
    2011 with a 100 and some odd thousand miles on the clock
  20. Dec 17, 2021 at 4:33 PM
    ABA180
    East Bridgewater MA
    You probably have another year or so anyway. My 2010 is still original, the hanger fell off this year but that was because of the frame rot. My wife's 2005 Rav4 lasted 12-13 years at about 130K
