Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jan 4, 2022 at 8:58 AM
    pvn.beluga
    pvn.beluga Well-Known Member
    Man I appreciate the community! I just got in line for a test at Bristol.
    lynyrd3, TOMB and Cativelense[QUOTED] like this.
  2. Jan 4, 2022 at 8:59 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :fingerscrossed:
    lynyrd3 and TOMB like this.
  3. Jan 4, 2022 at 12:43 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    How are the lines?
    lynyrd3 and Cativelense like this.
  4. Jan 4, 2022 at 2:20 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Look at all the parts I got (I need to return a couple because I ordered the wrong parts).
  5. Jan 4, 2022 at 4:01 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Who's ready for the snow on Friday?
    I think I am with the little wiring project I need to do.
  6. Jan 4, 2022 at 5:22 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I spoke too soon, again. The terminals I thought were wrong are in fact correct.
    The ones I ordered after thinking that the ones I ordered to begin with were wrong are in fact were the wrong ones.
    I am missing 16GA. terminals (couldn't find on https://www.waytekwire.com/), so I ordered those from a different site.
    You need "tanged" terminals if you buy the Bussmann RFRM that I did, even though people online say it uses "tangless".
    The site I ordered from says to use "tanged" and I thought it was a typo.
    Cativelense and TOMB like this.
  7. Jan 4, 2022 at 5:27 PM
    pvn.beluga
    It wasn’t that bad, the first group was there since 8am. Testing didn’t start until 11am. I got there at 10am, so waited until about 12pm.
    I waited in the Bristol Health parking lot until Bristol PD opened up the entrance for the Lot across the town hall.
    Then it was pretty quick. Results are 2-3 days - I’ll most likely be back for a 2nd test since exposure symptoms doesn’t show until 3-5 days…
  8. Jan 4, 2022 at 5:40 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    @HAVOC
    This may not apply to what your current project but it's a good source for electrical parts, terminals etc. spark plug wires, but this is
    probably good if you're restoring a 20's to 50's vehicle (cloth covered wires) etc.
    anyway, plenty of parts that may also help others if you're restoring an older cars motorcycles truck.
    I ordered from them for an older motorcycle repair good quality item's.
    https://enginebarn.myshopify.com/
    TOMB
  9. Jan 4, 2022 at 5:40 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    @Cativelense take a look at Lesser Evil. They were growing like weeds, probably hiring & in Brookfield near the P.D. Who wouldn't want to work in a Pop Corn Factory?
    lynyrd3 and Cativelense[QUOTED] like this.
  10. Jan 4, 2022 at 6:32 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Messed up three wires.
    I have a system now so I have less carnage.
    I was inserting the wires for the switches and realized that I had them inserted into the spot that is for the accessories.
    All fixed and it's good now. Everything will be checked with a multi-meter before any power is applied.
    Breakfast Taco, TOMB and Cativelense like this.
  11. Jan 4, 2022 at 6:34 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That is some antique looking stuff! :thumbsup:
    TOMB[QUOTED] and Cativelense like this.
  12. Jan 5, 2022 at 3:40 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy hump day.
    Breakfast Taco, lynyrd3 and TOMB like this.
  13. Jan 5, 2022 at 4:39 AM
    Cativelense
    Nuno
    CT
    Good ole Brookfield decided to make the call for a two hour delay super late.
    Danbury was already on a delay due to staff shortages this week, and a few minutes ago they decided to cancel.
    Guess we'll wait and see what Brookfield decides to do.
  14. Jan 5, 2022 at 4:46 AM
    Cativelense
    Nuno
    CT
    Just closed.
    Breakfast Taco and lynyrd3 like this.
  15. Jan 5, 2022 at 5:04 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Careful driving out there this AM, everyone... SUPER icy. Roads are a mess.
  16. Jan 5, 2022 at 5:05 AM
    Roody
    Ross
    SW CT
    GX460
  17. Jan 5, 2022 at 5:08 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Re-read the Bussmann thread and changed my method of wiring the RFRM.
    I ordered a couple connectors that I messed up. Hopefully they’ll be here Friday.
    lynyrd3, TOMB and Cativelense like this.
  18. Jan 5, 2022 at 5:46 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    It is an absolute "Ice Skating Rink" out there......you ain't kidding
    Breakfast Taco, TOMB, lynyrd3 and 2 others like this.
  19. Jan 5, 2022 at 9:38 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Coming together nicely.
  20. Jan 5, 2022 at 11:07 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Skierrichy, TOMB, Red Alert and 3 others like this.
