Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jan 7, 2022 at 2:35 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Okay then.. use the speed dial to post a good picture of you "stuckish".:D
  2. Jan 7, 2022 at 2:57 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    I gotta find the trails first :anonymous:
  3. Jan 7, 2022 at 6:14 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'd like to find any tracks in CT.
    (sorry for the "tracks" term, I've been watching a lot of off road videos from Australia)
  4. Jan 7, 2022 at 6:17 PM
    Brownmatthall
    2016 TRD OR DCSB
    Just finished up a bunch of 4wd 24/7 myself hahaha
  5. Jan 7, 2022 at 6:41 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    :thumbsup:
  6. Jan 7, 2022 at 9:27 PM
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 DCSB MGM
    What mount is that… …the antenna one.
  7. Jan 7, 2022 at 10:13 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    What area are you guys at?
    Cativelense and lynyrd3 like this.
  8. Jan 7, 2022 at 10:15 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Who wants to play hookie from work tomorrow and enjoy the snow hahaha. :ballchain:
  9. Jan 8, 2022 at 4:07 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I live in Branford.
  10. Jan 8, 2022 at 4:45 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Taking a ride back to the dealer today to see if I can order a different dash harness part number.
    The one I have is for a later build date (8/12-9/13) and I found out that date range also has a different ECM part number.
    I now have a new part number with a build date of 3/12-8/12 and that range uses the same ECM part number as my truck.
    It's all about what ECM is in the tuck. I should've done a little more research before ordering.
    Just looked at a wiring diagram for a 2013 Tacoma and it has different ECM connectors so I'm on the right track.
    Breakfast Taco, TOMB and Cativelense like this.
  11. Jan 8, 2022 at 5:01 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :hattip:
    -3* here
  12. Jan 8, 2022 at 5:08 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    20 here, supposed to get up to a balmy 31.
  13. Jan 8, 2022 at 6:25 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Saturday.
    Breakfast Taco, lynyrd3 and Red Alert like this.
  14. Jan 8, 2022 at 6:41 AM
    Brownmatthall
    2016 TRD OR DCSB
    Up on the north shore so probably not close enough :(
  15. Jan 8, 2022 at 8:29 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Took the part numbers I have to Toyota.
    The numbers I checked on all have been discontinued.
    So I'm stuck using the harness I bought. In a way it's a plus because it has the newer radio connectors so I don't have to run any adapter harnesses.
    I'll have to print out the EWD's I need and rewire two plugs for the ECM (all other connectors look to be the same).
  16. Jan 8, 2022 at 11:03 AM
    Brownmatthall
    2016 TRD OR DCSB
    You're way more tenacious than I would have been in your position haha
  17. Jan 8, 2022 at 1:06 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I have burnt/cut wires and to fix them plus add the wires I need for the accessories I'm adding would have taking the same amount of time.
    At least this way, I can do it from the comfort of my house and install the harness when it gets warmer.
  18. Jan 8, 2022 at 2:34 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Making connections are so much easier when you have the correct crimp tool.
    (this is for my Bussmann RFRM)
  19. Jan 9, 2022 at 4:44 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all
  20. Jan 9, 2022 at 5:48 AM
    lynyrd3
    Bill
    Currently freezing rain
    Morning Connecticut
    Skierrichy, Red Alert, TOMB and 3 others like this.
