Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Mar 10, 2017 at 2:59 AM
    #2421
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Supposed to be just 1-3" but I'm sure 84 will be the typical shit show...
    dcorbalis likes this.
  2. Mar 10, 2017 at 3:13 AM
    #2422
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    It always is my friend... It always is.
  3. Mar 10, 2017 at 3:52 AM
    #2423
    GPLarge
    GPLarge N1ALW
    Al
    Central CT
    2016 Tacoma SR5 Access Cab 4X4 2.7L
    84 on a Friday, you don't need snow to make ita shit show LOL
  4. Mar 10, 2017 at 4:04 AM
    #2424
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Roads are basically just wet...
  5. Mar 10, 2017 at 5:03 AM
    #2425
    Cativelense
    Nuno
    CT
    You can say that again.
    Indeed they were. The less traveled roads, or parts of the roads, were starting to get a bit slushy.
  6. Mar 10, 2017 at 5:58 AM
    #2426
    dcorbalis
    dcorbalis Well-Known Member
    DC
    New York
    2015 Toyota Tacoma SR5 ACLB Pyrite Mica
    DeeZee Bull Bar NFab Nerf Step Bars Softopper ATX
    IMG_2404.jpg Not thrilled
    Cativelense likes this.
  7. Mar 10, 2017 at 5:59 AM
    #2427
    Cativelense
    Nuno
    CT
    LOL!
  8. Mar 10, 2017 at 6:30 AM
    #2428
    Cativelense
    Nuno
    CT
    Forgot to mention something when I posted the pics of my retros.
    I am missing one pc before I can attempt to install it all. It's the wiring harness.
    Supposedly getting that today, so then I should have everything to attempt to the it all.
    Kinda freaking out a bit about the wiring part to be honest... I see a lot of wires coming out of the housing, and not quite sure where/how it all connects. :annoyed:
    Hoping once I get the lat part, and finally try to do this, it'll start to make sense somehow.
  9. Mar 10, 2017 at 7:53 AM
    #2429
    dcorbalis
    DC
    New York
    Good luck :fingerscrossed:
    Cativelense[QUOTED] likes this.
  10. Mar 10, 2017 at 7:53 AM
    #2430
    Cativelense
    Nuno
    CT
    Thank you sir! Scared shitless of it, not even gonna lie about it.
    dcorbalis[QUOTED] likes this.
  11. Mar 10, 2017 at 8:01 AM
    #2431
    consultadrone
    consultadrone Well-Known Member
    Orange County, CA
    '15 DCLB
    Heck yeah I will :thumbsup:
  12. Mar 10, 2017 at 8:03 AM
    #2432
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Is it plug & play? Should be. Depending on the kit, there may be relays that need power from the battery too. The halos probably will need to be spliced if you want them to be on when the parking lights are on.
  13. Mar 10, 2017 at 8:06 AM
    #2433
    consultadrone
    Orange County, CA
    '15 DCLB
    I'm always happy to help out fellow TW folks, especially the New England types. :bananadance:
    So, something like this?? :rofl::rofl::rofl: It's a '49. $500 and this sweet ride can be yours..
  14. Mar 10, 2017 at 8:06 AM
    #2434
    Cativelense
    Nuno
    CT
    Yeah, basically that. Waiting on one last part to make it plug and play, but need to splice something for the halos to be on with the DRLs, which is kinda freaking me out because I am not good at wiring anything, and I'm guessing I have to figure out/find out which wire I need to tap in to, and can't seem to find any info when I've searched for it.
    Gotta take some more time to try and do some more searches I guess when the last part comes in... thinking about putting it together before actually putting it on the truck, kinda like a trial run, so I can make sure I know what plugs into what, and what else needs to be plugged into what.
    consultadrone likes this.
  15. Mar 10, 2017 at 9:24 AM
    #2435
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Ok - here's how to do it. You need an automotive test light. Connect the test light to ground. Turn on the DRL's and probe from the back of the socket to see which wire is hot and which is ground. Next with the probe still attached, turn off the DRL's and make sure the test light goes out. The wire is color coded so write that down. Next turn on the turn signal and repeat to make sure the wire you think is it doesn't flash with the turn signals. Then trace that wire back to a convenient spot to tap into.
  16. Mar 10, 2017 at 9:27 AM
    #2436
    Cativelense
    Nuno
    CT
    Thank you sir!!!!!!!!!!! Guessing I can buy one of those thingies at autozone or some place similar??!!
  17. Mar 10, 2017 at 9:28 AM
    #2437
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There was a 47 near me (Prospect CT); check that - there were two and the guy wanted $750 for both. Lots of rust on one, second one was restorable. Needs to be an early 50's, preferably a 53-55. The truck is for wifey.
    Other preference is a 2 door 61-63 Falcon wagon - to go with my 63 convertible...
    Should be able to. It looks like a screwdriver with a sharp tip and a long wire/clip to attach to the battery or ground.
  18. Mar 10, 2017 at 12:34 PM
    #2438
    Cativelense
    Nuno
    CT
    Cool. I did a search on autozone and saw what you're describing.
    One of two things... I'm either overthinking this way way too much and it'll be super easy to do and I'm "psyching" myself out, or it'll be complicated as hell and I'll lose my shit trying to do it.
    :rofl:
  19. Mar 10, 2017 at 12:40 PM
    #2439
    consultadrone
    Orange County, CA
    '15 DCLB
  20. Mar 10, 2017 at 12:42 PM
    #2440
    Cativelense
    Nuno
    CT
    :rofl::rofl::rofl::rofl::rofl:
    DUDE!!! That's me right there... Mr Overthinker. :thumbsup:
