Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Apr 5, 2017 at 5:33 AM
    #2781
    dcorbalis
    dcorbalis Well-Known Member
    DC
    New York
    2015 Toyota Tacoma SR5 ACLB Pyrite Mica
    DeeZee Bull Bar NFab Nerf Step Bars Softopper ATX
    Saw someone with a Dark blue Taco that was lifted heading westbound on 84 on the NY line. Hurt my neck trying to get a look lol. Nice truck.
    Cativelense likes this.
  2. Apr 5, 2017 at 5:33 AM
    #2782
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Can't say I've seen that one yet. I've seen a red one once in a while that was pretty nice too.
    dcorbalis[QUOTED] likes this.
  3. Apr 5, 2017 at 8:26 AM
    #2783
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    I agree with @dcorbalis state park would probably be the best place for a meet up
  4. Apr 5, 2017 at 8:46 AM
    #2784
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    Some info from Alldata DIY:
    Based on 2015 Toyota Truck Tacoma 4WD V6-4.0L (1GR-FE) (IDK if the 13 is the same, use at your own risk)
    Filter OEM# 3533060050 $57.90
    Labor Information Skill Level B : Mfg. Warranty 0.0 : Standard 2.2
    Pan Gasket OEM# 3516860010 $23.24
    Automatic Transmission Fluid Capacity*
    5-speed models
    Vehicles without towing package 11.3 qt. (10.7L)
    Vehicles with towing package 11.5 qt. (10.9L)
    *: The fluid capacity is the quantity of reference.
    Your Vehicle: 2015 Toyota Truck Tacoma 4WD V6-4.0L (1GR-FE)
    Vehicle » Transmission and Drivetrain » Automatic Transmission/Transaxle » Service and Repair » Procedures » Replacement
    Replacement
    1. REPLACE AUTOMATIC TRANSMISSION FLUID
    (a) Lift the vehicle. [#1]
    NOTICE:
    Set the vehicle on a lift so that the vehicle is kept level when it is lifted up (make sure that the tilt angle from the front to rear of the vehicle is within +/-1°).
    (b) Remove the drain plug and gasket, and drain the ATF. [#2]
    (c) Temporarily install the gasket and drain plug. [#3]
    HINT
    Reuse the old gasket. The drain plug will be removed again to adjust the fluid level.
    (d) Remove the refill plug with O-ring, overflow plug and gasket. [#4]
    Text in Illustration
    (e) Add fluid to the refill hole until it flows out of the overflow plug hole. [#5]
    NOTICE:
    Use Toyota Genuine ATF WS.
    (f) Wait until the fluid flow slows and only drops come out. [#6]
    (g) Temporarily install the gasket and overflow plug. [#7]
    HINT
    Reuse the old gasket. The overflow plug will be removed again to adjust the fluid level.
    (h) Add fluid to the refill hole using the amount of fluid specified for removal and installation of the oil pan. [#8]
    HINT
    Specified amount of fluid is 1.7 liters (1.8 US qts, 1.5 Imp. qts).
    (i) Temporarily install the refill plug with O-ring to avoid fluid spillage. [#9]
    HINT
    Reuse the old O-ring. The refill plug will be removed again to adjust the fluid level.
    (j) Lower the vehicle. [#10]
    (k) Start the engine. [#11]
    NOTICE:
    Make sure that the A/C switch is off.
    (l) Slowly move the shift lever from P to L, and then back to P. [#12]
    HINT
    Slowly move the shift lever to circulate the fluid through each part of the transmission.
    (m) Allow the engine to idle for 30 seconds to warm it up. [#13]
    (n) Turn the ignition switch off. [#14]
    (o) Repeat steps [#1] to [#14].
    (p) Repeat steps [#1] to [#2].
    (q) Install a new gasket and drain plug.
    Torque : 20 Nm (204 kgf-cm, 15 ft-lbf)
    (r) Repeat steps [#4] to [#10].
    (s) Adjust the fluid level See: Adjustment.
    (t) Lower the vehicle.
    (u) Operation complete.
    jc11taco89 likes this.
  5. Apr 5, 2017 at 8:49 AM
    #2785
    vlodpg
    Connecticut
    Adjustment
    1. BEFORE REFILL TRANSMISSION
      • This transmission requires Toyota Genuine ATF WS or equivalent.
      • It is necessary to refill the transmission with the correct amount of fluid.
      • The vehicle must remain level while adjusting the transmission fluid level.
      • On vehicles equipped with active suspension, turn the suspension control switch off if it is necessary to jack up the vehicle with the engine running.
    1. TRANSMISSION PAN FILL
    (a) Remove the refill plug and overflow plug.
    (b) Fill the transmission through the refill hole until fluid begins to trickle out of the overflow tube.
    (c) Reinstall the overflow plug.
    1. TRANSMISSION FILL
    (a) Fill the transmission with the correct amount of fluid as listed in the table below.
    (b) Reinstall the refill plug to avoid fluid splash.
    HINT
    If you cannot add the listed amount of fluid, do the following:
    • Install the refill plug.
    • Allow the engine to idle with the air conditioning off.
    • Move the shift lever through entire gear range to circulate fluid.
    • Wait for 30 seconds with the engine idling.
    • Stop the engine.
    • Remove the refill plug and add fluid.
    • Reinstall the refill plug.
    1. FLUID CIRCULATION
    (a) Allow the engine to idle with the air conditioning off.
    (b) Move the shift lever through entire gear range to circulate fluid.
    1. FLUID TEMPERATURE CHECK
    NOTICE:
    The fluid temperature can be confirmed by checking the indicator light in the meter or by using the Techstream. When using the Techstream, it is necessary to change to temperature detection mode in order to idle the vehicle appropriately.
    (a) When using the Techstream:
    (1) Turn the ignition switch off.
    (2) Connect the Techstream to the DLC3.
    (3) Turn the ignition switch ON.
    (4) Enter the following menus: Powertrain / Engine and ECT / Active Test / Connect the TC and TE1.
    (5) Enter the following menus: Powertrain / Engine and ECT / Data List / A/T Oil Temperature 1.
    (6) Check ATF temperature.
    NOTICE:
    * If the fluid temperature is below 46°C (115°F), proceed to the next step. (Recommended ATF temperature: 36°C (97°F) or less.)
    If the fluid temperature is 46°C (115°F) or more, turn the ignition switch OFF and wait until the fluid temperature drops below 46°C (115°F).
    (7) According to the display on the Techstream, perform the Active Test "Connect the TC and TE1".
    HINT
    Indicator lights of the combination meter blink to output DTCs when TC and TE1 are connected.
    (8) Start the engine.
    NOTICE:
    Check that electrical systems such as the air conditioning system, audio system and lighting system are off.
    (b) When not using the Techstream (using indicator light):
    (1) Using SST, connect terminals 13 (TC) and 4 (CG) of the DLC3.
    SST : 09843-18040
    (2) Start the engine.
    NOTICE:
    HINT
    Indicator lights of the meter blink to output DTCs when terminals TC and CG are connected.
    (c) Slowly move the shift lever from P to L, and then return the shift lever to P.
    HINT
    (d) Move the shift lever to D, and quickly move back and forth between N and D (once within 1.5 seconds) for at least 6 seconds. This will activate the fluid temperature detection mode.
    Standard condition:
    A/T OIL TEMP warning light remains illuminated for 2 seconds and then turns off.
    (e) When using the Techstream:
    (1) Return the shift lever to P and terminate the Active Test on the Techstream.
    (f) When not using the Techstream:
    (1) Return the shift lever to P and disconnect terminals 13 (TC) and 4 (CG).
    (g) Allow the engine to idle until the fluid temperature reaches 36 to 46°C (97 to 115°F).
    (h) The A/T OIL TEMP warning light will come on again when the fluid temperature reaches 36°C (97°F) and will blink when it exceeds 46°C (115°F).
    Indicator Indication of ATF Temperature:
    NOTICE:
    * When checking the fluid temperature using the indicator light, make sure that the shift lever is in P.
    Perform the fluid level inspection while the indicator light is on.
    1. FLUID LEVEL CHECK
    NOTICE:
    The fluid temperature must be between 36°C (97°F) and 46°C (115°F) to accurately check the fluid level.
    (a) Remove the overflow plug with the engine idling.
    (b) Check that the fluid comes out of the overflow tube.
    If fluid does not come out, proceed to step 7.
    If fluid comes out, wait until the overflow slows to a trickle and proceed to step 8.
    1. TRANSMISSION REFILL
    (a) Install the overflow plug.
    (b) Stop the engine.
    (c) Remove the refill plug.
    (d) Add 0.4 liters (0.42 US qts, 0.35 Imp. qts) of fluid.
    (e) Allow the engine to idle and wait for 10 seconds.
    (f) Proceed to step 6.
    1. COMPLETE
    (a) Install the overflow plug with a new gasket.
    (c) Install the refill plug with a new gasket.
    Torque : 39 Nm (400 kgf-cm, 29 ft-lbf)
  6. Apr 5, 2017 at 4:31 PM
    #2786
    tgriff
    tgriff Well-Known Member
    Tim
    CT
    2014 TRD Sport 4x4 Black DCLB
    8.5" x 17" Fuel Hostage black wheels P265/65/R17 Toyo Open Country AT II tires Rigid Industries Dually LED pods on back bumper (Diffused pattern) Rigid Industries 10" SR2 amber LED light bar behind grille (Driving pattern) - Custom mount Magnaflow 18" performance muffler Magnaflow 4" resonator exhaust tip - Welded on 3M 35% tint on front windows Access Limited roll-up tonneau cover Uniden Bearcat 880 CB radio 4' Firestik Firefly CB antenna on Relentless Fab hood mount AVS vent visors Lamin-X amber fog light covers ND4's fog light anytime mod Ultragauge MX 1.3 mounted on dash - Custom mount Weathertech floor liners front & rear Access LED battery-powered bed light CravenSpeed stubby antenna OEM Bed Mat Bosch Icon windshield wipers Plasti-dipped front emblem Debadged TRD Sport bedside decals removed Mud flaps removed
    Cool; sounds like we all pretty much have the same idea:thumbsup:
  7. Apr 6, 2017 at 10:16 AM
    #2787
    Cativelense
    Nuno
    CT
    Happy Friday eve folks!
    Soggy out there... ARGH. Supposed to be nice next week though, so got that to look forward to at least.
    dcorbalis and jc11taco89 like this.
  8. Apr 7, 2017 at 3:06 AM
    #2788
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    IT'S FRIDAY!!!!! :woot:
    jc11taco89 and Cativelense like this.
  9. Apr 7, 2017 at 3:11 AM
    #2789
    Cativelense
    Nuno
    CT
    Indeed it is! Thank God!
    Happy Friday folks! Last night I put on that tailgate anti theft ring that scream makes and sells on here.
  10. Apr 7, 2017 at 4:24 AM
    #2790
    vlodpg
    Connecticut
    Happy Friday, May my interview go well this morning, good lunch this afternoon & rocking out this evening!
    dcorbalis, jc11taco89 and Cativelense like this.
  11. Apr 7, 2017 at 4:37 AM
    #2791
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    wunderground says 81 for Tuesday!
  12. Apr 7, 2017 at 4:44 AM
    #2792
    Cativelense
    Nuno
    CT
    Interview as in interview for a new job?
  13. Apr 7, 2017 at 6:46 AM
    #2793
    jc11taco89
    jon
    Naugatuck CT
    Hey just an FYI for anyone looking my company is looking to hire a warehouse guy if anyone needs a job, it's definitely Manuel labor and the pay isn't anything to write home about but it's a job
  14. Apr 7, 2017 at 12:55 PM
    #2794
    vlodpg
    Connecticut
    Yes! It is done!
    Be starting May 1st
  15. Apr 7, 2017 at 12:56 PM
    #2795
    Cativelense
    Nuno
    CT
    Nice! Congrats sir!!!!!!!!!!!!!
  16. Apr 7, 2017 at 12:57 PM
    #2796
    vlodpg
    Connecticut
    Again, I am starting from the bottom & clawing my way up. I am at 50% of what I made 1 year ago!
  17. Apr 7, 2017 at 12:57 PM
    #2797
    Cativelense
    Nuno
    CT
    That's the shitty part about starting over... bummer.
  18. Apr 8, 2017 at 5:04 AM
    #2798
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Happy sunny Saturday...
  19. Apr 8, 2017 at 5:21 AM
    #2799
    Cativelense
    Nuno
    CT
    Indeed. Happy Saturday folks!
    Debating whether or not I want to get in trouble with the wife over some rims that a NE member is selling over on the NE marketplace thread. :confused:
  20. Apr 8, 2017 at 5:23 AM
    #2800
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Hope everyone has had a chance to finally hit the trucks hard with power wash to remove any residual salt. I learned the hard way that the black trim between the fender flares and truck body will ripple and deform if you are too aggressive with the power washer. Be careful...
    Also I hit my truck again with a light fluid film spring spray. I have a little left if anyone wants some added protection for summer. $30 for the lighter spring application.
    tgriff and Cativelense like this.
