Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jan 14, 2023 at 12:52 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Happy Saturday CT. Up early cause I went to bed early because I was feeling partially under the weather.
    So much to do today (non truck stuff).
    I did not get the car that had the draw. I talked with the person who is looking at it and with the car off (push button start), you can still open/close the windows and sunroof. He's thinking body ECU.
    lynyrd3, CTSpruceMica and Cativelense like this.
  2. Jan 14, 2023 at 2:25 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Saturday.
    Off we go.
  3. Jan 14, 2023 at 4:14 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Yes, I'd love a coffee. Thank you.
  4. Jan 14, 2023 at 5:09 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Have fun and have a safe trip Nuno :thumbsup:
  5. Jan 14, 2023 at 5:09 AM
    lynyrd3
    Bill
    Morning Connecticut :hattip:
  6. Jan 14, 2023 at 9:33 AM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    My low end of professional scanner came in & I did some updating & reading on things hybrid.
    I do have P0A80 replace hybrid battery pack.
    BUT...
    My hybrid dive shows code P3019 - battery block 2 gets weak. Not bad - 'gets weak'.
    AND
    I also have ABS/VSC/TRAC error code and cruise control error code.
    C1235 is my dive in result - 'foreign object is attached on tip of front speed sensor RH.
    So, I've got a bad speed sensor or tooth.
    My reading on Prius chat showed something interesting,
    A bad speed sensor will throw an ABS, VSC, and Traction Control error.
    A bad speed sensor can cause the regenerative braking system to get confused & not charge the HV battery.
    If regen isn't charging the HV battery, the engine will keep turning on to charge the HV battery, but battery will keep running down first.
    ...causing the weakest battery block to "gets weak"?
    My battery blocks (pair of 2 cells) are showing 16.x volts. I want them showing 14.0-17.2v to be happy. They're happy.
    So annoyed the dealer said $4k for new HV battery without suggesting replacing the bad speed sensor first.
    I was ready to throw away this car. If there was a 15y.o. in my life I was ready to dump (er, give) it to them.
    I knew I had bad data. So, I bought an expensive reader & here we are.
    Will a speed sensor "fix" my car? Maybe, maybe not. But I'll sure start with a $220 part before the $4k job.
    I'll drop the car at my mechanic who has heat & a lift & is in walking distance. Have him see if it's a tooth or the sensor.
    Get whatever fixed, see how the car behaves after that. Drive it a little, clear the codes & maybe balance the HV batteries.
    Say - I came across an 'interesting' way to balance the HV cells. Definitely DIY, but...
    https://youtu.be/cqXahhZ_cYw
    I do have a gateway failure trouble code. This Blown IGBT video might be my other issue. Wonder what a junkyard inverter runs?
    https://youtu.be/QBoRSXIwZQs?t=1157
    My accessory battery the dealer told me I needed to replace immediately for $400, is 14.2 volts all these months later on a 40F day.
  7. Jan 14, 2023 at 11:57 AM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Just for fun did some research on inverter/converters. Part # G9200-47120 for my car.
    $250 used, $3,500 new at the dealer. used has a 6 month warrantee. They seem to only go bad if overheated. 6 months be plenty. I'll keep the $3,250 thank you.
    I enjoy wrenching on a car, but I wish I didn't HAVE TO.
    First World Problems I guess. :-\
  8. Jan 14, 2023 at 2:09 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I hope fixing the speed sensor issues fixes your other problems. If you do anything with the Hybrid system, be careful. You might want to look at getting a pair of protective gloves if you go that route.
    https://www.amazon.com/National-Saf...fos.f5122f16-c3e8-4386-bf32-63e904010ad0&th=1
  9. Jan 14, 2023 at 3:02 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    What's up CT?
    Making chicken and taking a bunch of Lexus tests.
  10. Jan 15, 2023 at 3:57 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Good morning CT
    Breakfast Taco, TOMB, lynyrd3 and 2 others like this.
  11. Jan 15, 2023 at 4:27 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Doing more tests while I do laundry. A lot of sales related stuff, I do see tech related stuff coming up.
    I'll forget almost everything I did because I won't use it for quite some time. Happens when I go to Lexus training also.
    I'm better at learning by doing, not reading stuff and taking tests.
    edit: finally made it to the technical stuff :thumbsup:
  12. Jan 15, 2023 at 5:39 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Sunday.
  13. Jan 15, 2023 at 5:40 AM
    lynyrd3
    Bill
    Morning Connecticut :wave:
  14. Jan 15, 2023 at 5:41 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Sure is windy out there!
  15. Jan 15, 2023 at 8:10 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    All done with the tests. :thumbsup:
  16. Jan 16, 2023 at 4:13 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Good morning. Only one Monday this week, don't sweat it
  17. Jan 16, 2023 at 4:14 AM
    lynyrd3
    Bill
  18. Jan 16, 2023 at 4:43 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    It's real messy out today, should've called in lol :pccoffee:
  19. Jan 16, 2023 at 5:33 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Messy?
  20. Jan 16, 2023 at 5:35 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Monday.
    Bout to head back home in a bit.
    lynyrd3, TOMB and CTSpruceMica like this.
