Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jun 27, 2023 at 3:30 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT. :wave:
    Holy crap! Thunder and lightning woke me up last night. Must have been directly over the house, shook the room. :eek:
    lynyrd3, TOMB, MikefromCT and 2 others like this.
  2. Jun 27, 2023 at 3:38 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Sounded like a bomb went off right over my roof, I was wide awake after that one lol
    lynyrd3, TOMB, MikefromCT and 3 others like this.
  3. Jun 27, 2023 at 4:06 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Same.
    Lying in bed thinking "maybe I should have taken down the aluminum flag pole on the front of the house last night"
    lynyrd3, Breakfast Taco, TOMB and 3 others like this.
  4. Jun 27, 2023 at 4:11 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Tuesday.
  5. Jun 27, 2023 at 4:27 AM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    That's odd...I heard nothing here.
    Today's the day! Unless there's any last minute fiddle fuckery from the dealership I pick up the Tacoma in just a few hours
    TOMB, lynyrd3, Breakfast Taco and 7 others like this.
  6. Jun 27, 2023 at 6:41 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    @HAVOC ,
    Would you have any interest in possibly taking a ride up to my place to help me with that chase light and switch install? Looking to ensure it’s installed before the Maine trip in August. Haven’t seen any mod days planned so figured Id ask if I can convince you to take a ride up and help for gas money, Guinness, hard cider, a woolwax spray or any combination of those.
    Switch comes today; connectors scheduled to arrive Thursday.
    Things I need to figure out:
    • Do I need a new grommet for the switch to go through the firewall, or if I could send it through the boot where my cb exits the cab.
    • Cleanly running the light wire from under the rtt where the light will be mounted to the recess where the brake light - was thinking of trying to run it to the bed cubby- drill a hole in the cubby door and use a grommet to make it look clean but need to brainstorm if there is a better/cleaner looking solution. My logic in putting it there is that the connector would be hidden/housed in the cubby, and would give easy access to splicing into the brake light for reverse, running and brake light functions.
    • Splicing the reverse, brake, and running light- what is the best way to accomplish this - thinking the t taps wouldn’t be the most weatherproof solution- was going to cut the current wires and use a heat shrink soldered butt splice but wonder if that is the best solution.
  7. Jun 27, 2023 at 8:33 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I could stop by. PM me your address. It probably won’t be until Saturday.
  8. Jun 27, 2023 at 9:29 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Thank you!
    It doesn’t have to be done as early as this Saturday, but if you dont have anything going on, that works for me. Maybe @CTSpruceMica will come by too. Ill send you a pm.
    lynyrd3, TOMB, Brownmatthall and 2 others like this.
  9. Jun 28, 2023 at 3:14 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    We should be able to use an existing grommet. Where does the CB antenna wire exit the cab?
    I won't be able to know where the best place will be to run wires until I see what we are working with.
    T-taps and the weather don't like each other. I've seen a lot of corrosion when T-taps are used outside. I don't use T-taps at all.
    The best would be to solder and then use marine heat shrink. Butt connectors and marine heat shrink would also work.
  10. Jun 28, 2023 at 3:16 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT. Happy Wednesday!
    Work dinner tomorrow night at a new Mexican place 3 minutes from my house.
  11. Jun 28, 2023 at 3:57 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning nutmeggers
  12. Jun 28, 2023 at 4:34 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy hump day.
    Heading to Ocean City MD tomorrow for a few days with family and friends.
  13. Jun 28, 2023 at 7:29 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here’s a blast from the past. 2004 IS300, 45,000 miles.
    Roody, lynyrd3, TOMB and 4 others like this.
  14. Jun 28, 2023 at 7:18 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Taco passed inspection today. 219,845. I always worry but no issues. :yay:
  15. Jun 29, 2023 at 3:05 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT. Happy Thursday!
  16. Jun 29, 2023 at 3:09 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :wave:
  17. Jun 29, 2023 at 3:39 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  18. Jun 29, 2023 at 3:40 AM
    Offbeattacos
    Offbeattacos Well-Known Member
    Kyle
    Wallingford, CT
    2020 TRD Sport MT cement
    heyoooo!
    Well tomorrow after work, the missus and I will be taking miata out for the 10th anniversary of owning it. The plan is to go up to Kent Falls State Park for a hike and maybe to Kent Falls brewing company. Is there anything else anyone would like to recommend for us to stop at on this trip? We are heading out from Wallingford.
    Cativelense, TOMB and MikefromCT like this.
  19. Jun 29, 2023 at 5:17 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Stop by Lime Rock...
  20. Jun 29, 2023 at 5:25 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Morning everyone,
    Almost Friday!
    Dropped the truck off at town fair for new rubber and an alignment. So excited for these new tires :bananadance:
    Cativelense, Roody, TOMB and 2 others like this.
