Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Aug 27, 2023 at 7:26 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    I'm not Irish, but use the Irish Goodbye regularly
  2. Aug 27, 2023 at 8:03 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Anyone here familiar with GMC cars and their "issues" by chance?
    Want to pick your brain and ask a question about something that happened to the Mrs' 14 Acadia Denali.
  3. Aug 27, 2023 at 8:22 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    :annoyed:
    Doing up some heat shrink on the fuse box. I had the heat gun set to low, it goes to "high" and then I see smoke. :eek: Unplugged it immediately.
    Now I need a new heat gun.
    Cativelense likes this.
  4. Aug 27, 2023 at 8:26 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Wow...Ryobi makes EVERYTHING
  5. Aug 27, 2023 at 10:51 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not a pro, but spill it
    Cativelense[QUOTED] likes this.
  6. Aug 27, 2023 at 11:53 AM
    Cativelense
    Nuno
    CT
    The sound in the car stopped working. All of it.
    Radio, blinker sound, DVD player, everything.
  7. Aug 27, 2023 at 12:59 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    https://www.cargurus.com/Cars/Discussion-t24939_ds656313
    Edit: the water in the door wiring harnesses makes a lot of sense given the type of failures and control module
  8. Aug 27, 2023 at 1:27 PM
    Cativelense
    Nuno
    CT
    I've checked and seems dry. Not to mention the car is garaged and hasn't really been out in the rain lately.
    Might have to make a trip to the stealership.
  9. Aug 27, 2023 at 1:44 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Play with the harness that goes to the L/F door and see if stuff works/doesn’t work.
  10. Aug 27, 2023 at 2:17 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Out of the vinegar bath and into the oil, olive,that is.
    I let em set a couple weeks before consuming. :hungry:
    Cativelense and CTSpruceMica like this.
  11. Aug 27, 2023 at 2:22 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Is that prosciutto?
    On my phone and can't see shiiit
  12. Aug 27, 2023 at 2:37 PM
    bucktales
    But of course.
    Wrapped around Parmesan.:cookiemonster:
  13. Aug 27, 2023 at 2:42 PM
    Cativelense
    Nuno
    CT
    I'll mess around with it and see what happens.
    CTSpruceMica likes this.
  14. Aug 27, 2023 at 4:07 PM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Hit up the Terryville fair with the family last night. Got 99% of the deck boards installed on the front porch. Need to bend some aluminum to tidy up the corner pieces of siding on the bottom two rows. The end caps got mangled pulling them off when the project began, but was able to salvage one enough to make a template out of. Picked up a roll of aluminum trim and will cut some blanks out tonight. I dont have a brake but do have a nice milwaukee seamer that might do the job. If that doesn’t work, ill just rent a brake for a half a day. Also need to schedule a rental for an aerator/overseeder for September since the front will be all cleaned up and ready for seed. Rest of the yard can use it too.
  15. Aug 27, 2023 at 4:53 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    you broken. :) Probably go to bed before 3am too. Insanity!
    CTSpruceMica and Cativelense like this.
  16. Aug 27, 2023 at 5:13 PM
    ABA180
    East Bridgewater MA
    Yup. I remember my 06 Colorado when I replaced the factory radio having to buy the (I think) RS1 module as the factory bells/chimes all work through the radio. This module replaced that function.
    TOMB, CTSpruceMica and Cativelense like this.
  17. Aug 28, 2023 at 3:30 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Good Monday morning Connecticut
  18. Aug 28, 2023 at 4:57 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT. A coworker made me lasagna for my birthday.
  19. Aug 28, 2023 at 4:58 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Good person right there
  20. Aug 28, 2023 at 5:17 AM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    Lasagna...a solid choice. That was very nice of them!
