Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Feb 26, 2024 at 6:15 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    SIL did quite a bit of immigration and citizenship work earlier in her legal career. I'll pass along any questions she might be able to help you with
    TOMB and Cativelense[QUOTED] like this.
  2. Feb 26, 2024 at 6:33 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Thanks so much Dennis. I think right now I'm good, but I'll keep that in mind.
    The lady at the agency that helped my parents submit the paperwork gave them a paper with questions that they ask at the citizenship test. I was reading through it yesterday when we went over for lunch after church. A lot of those questions are things you learn in school if you are lucky enough to move here while you're still young, and go through the school system. And a lot of them are also "common knowledge" type questions. There were 100 questions on there. Not sure how many they actually ask on the test. My father said that the lady told him because he's over 65 they only ask them 20 questions and supposedly if you get 6 correct, even if you don't get asked all 20 you're done and you pass. But depending on the person that's administering the test they may ask all 20 anyway.
    I feel pretty confident if the paper the lady gave my father is a good example of what I'd be asked on a test. I was lucky enough to move here when I was 12, so I learned some stuff about government, etc. And I'm lucky that my 9 year old is starting to learn about government already in 4th grade and knew a lot of the questions they asked about that, so I learned from him as well. LOL.
  3. Feb 26, 2024 at 7:31 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    @NUNO
    Good luck to you and you know my wife went through the same thing. A lot of questions about the government at that time, but that was over 35 years ago one of the big adder was for her was that she was a bilingual, English and French. So you're bilingual Portuguese? I think that should be an adder, but the questions are common sense at that time. You'll do fine, just do what they say. Make sure every.is there and every T is crossed and every period is where it's supposed to be. Good luck
    TOMB
  4. Feb 26, 2024 at 7:34 AM
    Cativelense
    Nuno
    CT
    Thanks so much Tom. And yes, bilingual: Portuguese and English.
    Apparently they offer the test in other languages as well. My parents are taking it in Portuguese because of the language barrier. I've been here for so long that if I took it in Portuguese I'm sure I'd fail. LOL
  5. Feb 26, 2024 at 6:22 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Looked at my niece's van after work today. Needs a fuel pump. I don't think it's worth it with the amount of rust that thing has. The rocker panels are not there.
  6. Feb 27, 2024 at 3:04 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Tuesday.
    TOMB and CTSpruceMica like this.
  7. Feb 27, 2024 at 3:06 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning.
    I wasn't able to look at the fuse block last night because of my niece's van. I'll look at the thing tonight and see why it's acting weird.
    The only thing common between the relays is that they get power and ground from the same place but that shouldn't cause the issue I'm having.
    CTSpruceMica and Cativelense like this.
  8. Feb 27, 2024 at 4:08 AM
    Offbeattacos
    Offbeattacos Well-Known Member
    Kyle
    Wallingford, CT
    2020 TRD Sport MT cement
    Maiden voyage to work and the roof box is still over the bed. Id love a leer cap or to build a pop up camper to put in the bed, but this is okay for now for when I do a trip and need extra storage.
    Breakfast Taco, TOMB, Roody and 4 others like this.
  9. Feb 27, 2024 at 3:48 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  10. Feb 27, 2024 at 4:44 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Cativelense likes this.
  11. Feb 27, 2024 at 6:11 PM
    Cativelense
    Nuno
    CT
    FUCK ME.
    I just got over the nasty cold I got right after the Mrs got over Covid, and now she gave me a cold again.
    Post nasal drip all day, tickle in my throat, and now congestion.
    ARGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Roody likes this.
  12. Feb 27, 2024 at 6:18 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    The perils of being married to an elementary school teacher...I've lived your life...
    Cativelense[QUOTED] likes this.
  13. Feb 27, 2024 at 6:23 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    I'd love to see an aerodynamic study of the truck w/ box like that vs. w/ the box spun around.
  14. Feb 27, 2024 at 6:26 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Hmm...yes...Kamm tail effect
  15. Feb 27, 2024 at 6:44 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    People. I have two minutes to myself so I can relax and it's "Harry, I need this".
    I get home, eat and sit on the couch. Phone starts ringing immediately.
  16. Feb 27, 2024 at 6:49 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
  17. Feb 27, 2024 at 7:16 PM
    Cativelense
    Nuno
    CT
    Well... Decided to test myself just in case, and bam.
    Got the rona.
    You gotta be fucking kidding me.
  18. Feb 27, 2024 at 7:19 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Is this the 2nd time?
  19. Feb 27, 2024 at 7:28 PM
    Cativelense
    Nuno
    CT
    Yup.
    So pissed. No clue where or how I got it.
    The Mrs had it and we all managed to not catch it. Now she's fine, and I catch it. Hoping I didn't give it to the kids.
    CTSpruceMica[QUOTED] likes this.
  20. Feb 28, 2024 at 3:20 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That's just what I may be doing this evening after work. Phone rang 5 times and when I go help my brother in law jump his Jeep, it rang two more times.
    I have stuff in my house that I'm trying to go through. I get free time to actually do it and nope. I still haven't looked at the issue with my fuse box either.
