Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Feb 6, 2025 at 1:29 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Good morning CT. I woke up expecting snow on the ground.
    Bought some more wire, I may go up a size for the small wires going to the relay for the compressor, 14 gauge instead of 16 gauge. I should get all of my stuff that I ordered on Friday. Wire, fuse holder, relay holder, etc.
    I'll get the compressor wired up after mounting the Auxbeam under the hood. It's nice that when the Auxbeam is mounted, you can still get under it to run wire. I just need to figure out the main ground wire, I'll do that on lunch today or after work. I'm going to assume it'll be slow today and I could clock out early.
    Cativelense and lynyrd3 like this.
  2. Feb 6, 2025 at 3:17 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    @Roody
    Been four days...think I'm gonna be good
    Roody, Cativelense, lynyrd3 and 2 others like this.
  3. Feb 6, 2025 at 4:03 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    My wife has the flu for a week and is slighly annoyed I dont.
  4. Feb 6, 2025 at 4:22 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I just yelled at @EricM that he’s probably got the flu and to go home.
    Hope Tiff is feeling better!
  5. Feb 6, 2025 at 4:37 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :hattip:
    Snowing here ,roads covered
    CTSpruceMica and Cativelense like this.
  6. Feb 6, 2025 at 4:40 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Friday eve.
    Coming down pretty good over here.
    TOMB and CTSpruceMica like this.
  7. Feb 6, 2025 at 4:45 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Same here. Stopped at the coffee place on my way to work for a bagel.
  8. Feb 6, 2025 at 4:53 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    Tell Tiff you need to stay well to lovingly care for her in her time of need
    Brownmatthall, TOMB and Cativelense like this.
  9. Feb 6, 2025 at 5:14 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    More like
  10. Feb 6, 2025 at 5:25 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning
    TOMB, Cativelense and CTSpruceMica like this.
  11. Feb 6, 2025 at 5:50 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Goddamn am I glad to hear that
  12. Feb 6, 2025 at 6:37 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Just did a 10,000 mile service on a RZ450e. Check air pressure and fill washer fluid.
    CTSpruceMica, Cativelense and Roody like this.
  13. Feb 6, 2025 at 7:55 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    For every 1 time I get sick Audrey goes down like 4 or 5, she doesn't appreciate it either lol
  14. Feb 6, 2025 at 9:54 AM
    Cativelense
    Nuno
    CT
    Went out and cleared the driveway a while ago.
    The snow stopped, and whatever it was doing was very light. Couldn't tell if it was rain, or sleet.
    Used the shovel... wasn't very heave and wasn't a lot to make it worth using the snowblower.
    Now it's doing something, but hard to tell if it's rain or sleet because everything is frozen on top so it sounds like it's just hitting the frozen layer on top.
  15. Feb 6, 2025 at 10:02 AM
    Roody
    Ross
    SW CT
    GX460
    Yeah it's a mess out there. Snowed about 1" overnight then wintry mix in the AM then sleet (?) now rain (??) but the ground is cold so it might be freezing (???)
    Cativelense likes this.
  16. Feb 6, 2025 at 12:46 PM
    Cativelense
    Nuno
    CT
    My kid is supposed to have practice tonight at 7.
    So far haven't heard anything about it being canceled, so guess we'll see what happens.
  17. Feb 6, 2025 at 1:34 PM
    Jrs13086
    Jrs13086 [OP] Well-Known Member
    CT
    2023 TRD Sport LR
    Nothing yet
    Afternoon all. What a slushy shitty day. Snow here has basically melted.
  18. Feb 6, 2025 at 1:48 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Me, anal about electrical? I don’t know what you’re talking about. :anonymous:
    lynyrd3, TOMB, Roody and 2 others like this.
  19. Feb 6, 2025 at 1:59 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    You're "detail oriented"
    lynyrd3, TOMB, asl0621 and 2 others like this.
  20. Feb 6, 2025 at 3:00 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Ooooh! Pretty.
    TOMB, Roody and Cativelense like this.
