Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jul 16, 2025 at 1:54 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Europenne Mounts. Kind of Like you did normally aren't that expensive. At least not down here they aren't. Somewhere between $175.00 to $250.00 depending what you want done. Full mounts are getting pretty pricy all over and if the Taxidermist is a Quality Taxidermist you could be waiting a while to get you mount back.
  2. Jul 16, 2025 at 2:02 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    I picked up a metal pedestal off Amazon for it and looks pretty good.
    I had wrapped the antlers heavy with foil above ground and put a large flower pot over them to keep the rodents away.
    Put some large rocks over it as well to prevent some other critter from digging it up. :rofl:
  3. Jul 16, 2025 at 5:25 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Evening CT.
    Got the camera wiring run through the firewall on lunch. Tomorrow on lunch I need to send the temp sensor wires back through the firewall and start with the compressor harness.
    I was going to do some stuff after work but it was too hot and humid today and I had a bad headache so I took a nap after getting home.
  4. Jul 16, 2025 at 8:20 PM
    lynyrd3
    Bill
    East Central Upstate NY
    So far so good at Hammonassett ! Only rained Monday night a little bit .
    TOMB and Cativelense like this.
  5. Jul 17, 2025 at 2:53 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    :wave:
    Good morning.
    Got the compressor harness ready to put in the truck so I can cut the wires to the correct length. I'm using the original ARB connector and not a weatherproof one (couldn't get a good crimp).
    TOMB, lynyrd3 and Cativelense like this.
  6. Jul 17, 2025 at 4:46 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Friday eve.
  7. Jul 17, 2025 at 5:43 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Ran into an issue on the way to work today. About to get off the exit and developed a bad vibration, step on the brakes to slow down, vibration got worse. Looking at it on lunch.
    I checked wheel torque and went to park it. Check engine light and TRAC Off lights came on.
    TOMB likes this.
  8. Jul 17, 2025 at 6:15 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Dislike
    Watching for updates:popcorn:
  9. Jul 17, 2025 at 6:17 AM
    Cativelense
    Nuno
    CT
    Disfucking like.
    lynyrd3 and TOMB like this.
  10. Jul 17, 2025 at 6:34 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Of course. I put the stuff in the truck this morning so I can wire the compressor and this happens.
  11. Jul 17, 2025 at 10:27 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Seized L/F caliper and some codes. Cleared them for now. Will keep an eye open.
    TOMB, AllTacosFloat and Cativelense like this.
  12. Jul 17, 2025 at 10:54 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Possibly from off roading last weekend? Not sure how, just throwing it out there
    Cativelense likes this.
  13. Jul 17, 2025 at 11:03 AM
    lynyrd3
    Bill
    Back home from Hammanasset a day early . Had a great time weather was good . Huge shady camping area with no neighbors near by . Hit some rain on the way home this morning .
  14. Jul 17, 2025 at 6:12 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    It's possible but I don't know why it waited. I knew the caliper was bad.
  15. Jul 17, 2025 at 6:15 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Cleared the codes during lunch. Check all wires going to rear axle, those are good.
    I'll see what each code has in common. The lights stayed off during the ride home. Did get some shimmy from the brakes but I did not drive on the highway.
    Cativelense and TOMB like this.
  16. Jul 17, 2025 at 6:59 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Think I'll use my new Autel scan tool and diagnose the codes that I had. I'll have to see if I can use it to do an automatic EVAP test.
    Should be able to, does a lot of other stuff.
    We will see if the lights come back on during the commute tomorrow.
  17. Jul 18, 2025 at 2:39 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  18. Jul 18, 2025 at 3:29 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Morning guys, happy Friday
    Kid 1 woke up around 945 last night and puked... so that's fun...
    TOMB, lynyrd3 and CTSpruceMica like this.
  19. Jul 18, 2025 at 4:36 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Friday.
  20. Jul 18, 2025 at 4:36 AM
    Cativelense
    Nuno
    CT
    Disfucking like.
    Hope they're OK, or feeling better now.
    TOMB, lynyrd3 and Roody[QUOTED] like this.
