Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Dec 29, 2017 at 3:02 AM
    #4881
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Good morning everyone.
    TGIF and happy last Friday of 2017.
    jc11taco89 and Irongrave like this.
  2. Dec 29, 2017 at 5:13 AM
    #4882
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  3. Dec 29, 2017 at 5:44 AM
    #4883
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    I know that intersection - use it every weekday.
    natural gas is one of the reasons I'm in the house I'm in. now if you know a 3rd+ generation mason to rebuild my chimney in the spring.....
    Cativelense likes this.
  4. Dec 29, 2017 at 10:08 AM
    #4884
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    I don’t know about third gen masons but I do have a guy I have used several times. Has rebuilt several chimneys that I know of (2for me) as well as stone walls, the stucco over my garage (needed new steel support) and some other projects. They do good work, let me know if you want me to PM you the contact.
  5. Dec 29, 2017 at 11:33 AM
    #4885
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    Hey all so I got that welder for Xmas and it's the hobart handler MVP 210 and it runs on 115/ 230. So I have the standard 120 in my garage and j would definitely like to upgrade to 240 anyone know any electricians that do side work or anything?
    Irongrave and Cativelense like this.
  6. Dec 29, 2017 at 11:34 AM
    #4886
    Cativelense
    Nuno
    CT
    My dad does... not sure if he's be up for going up there though... probably would depend on his schedule, but I'll ask him and see what he says. I'm seeing him tomorrow night, I think, so I'll keep you posted.
    EDIT: Both of my cousins do as well, so I'll ask them too.
    jc11taco89[QUOTED] likes this.
  7. Dec 29, 2017 at 8:27 PM
    #4887
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I went ahead and got my new exhaust system built with the Black widow 2.5" Venom 250 muffler coming out behind the passenger rear wheel. I have the Venom 250 muffler with an AFe Stage-2 Si Pro 5R Cold Air Intake System Dry filter. It was 11F this morning when I shot the video while starting the truck.
    I really do like the sound of the Venom 250 on my truck so far. The initial firing up sound is aggressive and loud enough but doesn't scare small children. With that said, your neighbors will definitely know when you have started your truck because the exhaust note travels inside the house easily. Just under normal idle while sitting at a light or in a drive through you wont notice it to much, but once you get on the throttle you and everyone around you will hear it.The idle time is relaxing for the most part. She really starts to sing when you are pulling through the parking lots and especially getting onto the highway or passing anyone, that just puts a smile on my face.
    The biggest thing that I noticed with this muffler compared to the last system that was on my truck is how much "quieter" the Black widow muffler sounds inside the cab, It doesnt sound annoying or overly loud. It has some hum at 1500 rpm, but my old aftermarket exhaust system hummed at the same RPM, so going 35 down the road you might have a little bit but not an annoying drone. At 2k RPM while doing 70mph the exhaust is comfortably quiet and easy to drive, but once you bring the motor up to 3200 RPM she stops sounding like a Tacoma and sounds more like a beast.
    Black Widow mufflers are definitely a company to look into if you want a very different sound compared to other Tacomas on the road.
    jc11taco89 and Cativelense like this.
  8. Dec 29, 2017 at 9:03 PM
    #4888
    jc11taco89
    jon
    Naugatuck CT
    Definitely sounds pretty good I'm gonna have to check this out I think, when you say "exhaust" do you mean like a cat back or full system
  9. Dec 29, 2017 at 9:39 PM
    #4889
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    I had a shop build me a cat back system. The aftermarket exhaust that was on the truck rusted out and had to be cut off ahead of the muffler. I bought the muffler from http://www.blackwidowexhaust.com direct and then took it to an exhaust shop and had him bend me the new pipe out of stainless to match the factory run and weld the new muffler and new pipe in place.
  10. Dec 30, 2017 at 6:08 AM
    #4890
    Cativelense
    Nuno
    CT
    Good morning everyone! Happy Saturday!
    jc11taco89 likes this.
  11. Dec 30, 2017 at 6:24 AM
    #4891
    jc11taco89
    jon
    Naugatuck CT
    Soo just in case anyone hasn't noticed yet it's snowing :thumbsup:
  12. Dec 30, 2017 at 6:26 AM
    #4892
    Cativelense
    Nuno
    CT
    Yeah... putting a damper on the plans the wife had for today. No more running errands, for now.
  13. Dec 30, 2017 at 11:23 AM
    #4893
    santas212
    Georgetown, CT
    Time for snow driving practice!
    Cativelense[QUOTED] likes this.
  14. Dec 30, 2017 at 11:30 AM
    #4894
    Cativelense
    Nuno
    CT
    Naw. Got enough of that already. Time for staying home and getting the kiddos' Christmas gifts (tons of clothes) put away.
  15. Dec 31, 2017 at 5:25 AM
    #4895
    Cativelense
    Nuno
    CT
    Good morning everyone! Happy Sunday! Happy new year's eve! Every one be safe later if you're out and about.
  16. Dec 31, 2017 at 6:20 AM
    #4896
    jc11taco89
    jon
    Naugatuck CT
    Morning all Happy last day of 2017.
    Cativelense and vssman like this.
  17. Dec 31, 2017 at 6:24 AM
    #4897
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning! Happy New Year's Eve...
    Cativelense and jc11taco89 like this.
  18. Dec 31, 2017 at 12:13 PM
    #4898
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Xmas day part 2.
    This time it's the older grandkids 17 & 15. They live by the casinos and there lives are taking the high school route. They are both in Norwich Free Academy. Good students. Then you get the younger grandkids who are also here so it's a homecoming of sorts. Sort of like a Norman Rockwell picture.
    I really enjoy these moments.
    Happy New Year to all.
    TOMB
  19. Dec 31, 2017 at 4:17 PM
    #4899
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Soooo, I tried to beat the snow which I heard wouldn't start until noon.
    Picked up a Uhaul with the Tacoma. 4 pin wasn't working, went to the mechanic who had me set in an instant, back to Uhaul & hooked up a 6x12 trailer w/ ramp. Went to New London & back to Danbury in all this mess. Definitely worse along the coast, roads iced, more snow... Must have passed 7-10 accidents. Had a landscaper towing an excavation rig on a trailer jack-knife in front of me, barely missed him, barely avoided jack-knifing myself despite the trailers valiant effort to.
    By the time I got home I was so exhausted I passed out around 8:30pm! LOL, I'm usually up until 1 or 2 am.
    That trip sucked!
    HAPPY NEW YEAR EVERYONE!
  20. Dec 31, 2017 at 9:07 PM
    #4900
    santas212
    Georgetown, CT
    Happy New Year!
