Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Feb 27, 2018 at 3:05 AM
    #5261
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all...
  2. Feb 27, 2018 at 8:43 AM
    #5262
    dcorbalis
    dcorbalis Well-Known Member
    DC
    New York
    2015 Toyota Tacoma SR5 ACLB Pyrite Mica
    DeeZee Bull Bar NFab Nerf Step Bars Softopper ATX
    Had to go to Mavis again this morning for a re-alignment. I kept having to keep the wheel turned to the right to keep the truck driving straight. Mavis said everything was fine. But I still have to keep it more to the right than it was before. Anyone else have this problem? Oh and as I was driving to work the low air sensor went on :annoyed:
  3. Feb 27, 2018 at 8:48 AM
    #5263
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    DANG MAN. That sucks right there. My TPMS sensor has been coming on and off ever since I got my winter tires put on. Don't really care right now since we're so close to spring, and I'll get my wheels swapped again.
    Your steering thing though... yeah, I have no clue what's going on there. Maybe steering rack issue?! :notsure:
    dcorbalis[QUOTED] likes this.
  4. Feb 27, 2018 at 8:51 AM
    #5264
    MacMedic
    MacMedic Well-Known Member
    2016 Black Tacoma TRD Sport
    Check and reset your tire pressures (make sure you don't have a leak). This could cause the pull in the front end....
    Not so sure about these Mavis places ... everyone that uses them seems to have issues with their work...!!
    Sandeman and dcorbalis like this.
  5. Feb 27, 2018 at 9:24 AM
    #5265
    dcorbalis
    DC
    New York
    I dont know. Gonna bring it back tomorrow and they're going to check it out. All the tires still have air. If they cant figure it out im gonna take it to toyota.
  6. Feb 27, 2018 at 10:12 AM
    #5266
    tgriff
    tgriff Well-Known Member
    Tim
    CT
    2014 TRD Sport 4x4 Black DCLB
    8.5" x 17" Fuel Hostage black wheels P265/65/R17 Toyo Open Country AT II tires Rigid Industries Dually LED pods on back bumper (Diffused pattern) Rigid Industries 10" SR2 amber LED light bar behind grille (Driving pattern) - Custom mount Magnaflow 18" performance muffler Magnaflow 4" resonator exhaust tip - Welded on 3M 35% tint on front windows Access Limited roll-up tonneau cover Uniden Bearcat 880 CB radio 4' Firestik Firefly CB antenna on Relentless Fab hood mount AVS vent visors Lamin-X amber fog light covers ND4's fog light anytime mod Ultragauge MX 1.3 mounted on dash - Custom mount Weathertech floor liners front & rear Access LED battery-powered bed light CravenSpeed stubby antenna OEM Bed Mat Bosch Icon windshield wipers Plasti-dipped front emblem Debadged TRD Sport bedside decals removed Mud flaps removed
    Yes, i had the same problem when i got my new tires, the alignment is just off, even if they are telling you its good. Aparently theres an easy way to do an alignment and a hard way. If they take the easy way out, they dont worry about keeping the wheel straight during the alignment. This means the alignnent is good and within spec, but the steering wheel will not be straight when you are driving straight. I brought mine back and the problem was fixed with a new alignment
  7. Feb 27, 2018 at 10:39 AM
    #5267
    dcorbalis
    DC
    New York
    I'm thinking they were taking the easy way lol
  8. Feb 27, 2018 at 10:40 AM
    #5268
    Cativelense
    Nuno
    CT
    Fucked up. Go back and make them do it again, and see if you can watch them do it.
  9. Feb 27, 2018 at 12:01 PM
    #5269
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    The other thing that could be a problem other than the alignment even though they are new Wheels tires Etc the tire itself might be the size you require but it might be slightly larger or slightly smaller in overall diameter compared to the left front or the right front the easy way out swap one of the back ones from the same side to the front and then go from there could be nothing more than a tire that is slightly bigger outside dia. or needs to do with playing with inflation pressures
    TOMB
    dcorbalis and Cativelense like this.
  10. Feb 27, 2018 at 2:00 PM
    #5270
    redrelyt12
    redrelyt12 Well-Known Member
    Tyler
    2016 Tacoma TRD Sport DCLB
    Derped TRD Sport Grille BAK Revolver X2 Tonneau Cover mattgecko Waterproof LED Hood & Bed light kits Southern Style OffRoad Slimline Hybrid Front Bumper Baja Designs 20" S8 Light Bar Smittybilt X2O-10 Winch Blue 3/4" Shackles
    I think you're all over thinking this. The tires being in alignment have no affect on your steering wheel being straight. They are independent. You should be able to have them adjust the drag link to straighten your steering wheel
    dcorbalis likes this.
  11. Feb 27, 2018 at 2:37 PM
    #5271
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    There's no drag link. Adjustment is done entirely via outer tie rod ends. But you are correct theres no reason they shouldn't be able to get the alignment and steering wheel straight. Chances are it's the guys who did the alignment. I had a similar problem at the toyota dealership. They swore up and down that there was something wrong cause there was no possible to get the steering wheel straight. Took it to a local shop and the had it done in like 30 minutes. Local shop said they had issues and didn't see where the dealer thought there was a problem.
  12. Feb 27, 2018 at 8:45 PM
    #5272
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    I know a good weld shop in bethel I have used. Don’t know if that’s too far out of your way. They don’t do vehicles specifically but if you show them a photo they will make it. Might not be your cheapest option though.
    Cativelense likes this.
  13. Feb 28, 2018 at 2:43 AM
    #5273
    Cativelense
    Nuno
    CT
    Morning everyone. Happy hump day.
    Sandeman likes this.
  14. Feb 28, 2018 at 2:59 AM
    #5274
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning Nutmeggers!
    Someone started a business in NEPA making things for the Tacoma. I think they are called Kore or something similar.
    Edit: found them! They are called Kore. @Skell
  15. Feb 28, 2018 at 4:05 AM
    #5275
    Sandeman
    Sandeman Well-Known Member
    Home of the Headless Horseman, NY
    '17 TRDOR, '04 GX470
    I have fab shop that we use for our home building but they aren’t truck saavy as well :/ wanted a place locally that would fab and install
  16. Feb 28, 2018 at 4:06 AM
    #5276
    Sandeman
    I actually reached out to him! Downside His shop is 3-1/2 hours away wanted to see if there’s something closer- his prices are awesome!
  17. Feb 28, 2018 at 4:33 PM
    #5277
    Cativelense
    Nuno
    CT
    How did you make ououwith out with the alignment @dcorbalis?
  18. Feb 28, 2018 at 4:51 PM
    #5278
    Cativelense
    Nuno
    CT
    FAK
  19. Feb 28, 2018 at 8:51 PM
    #5279
    santas212
    Georgetown, CT
    Not psyched about the rain. Hoping Vermont at least gets killed with snow.
    On the + side it’s payday!
  20. Mar 1, 2018 at 2:41 AM
    #5280
    Cativelense
    Nuno
    CT
    Morning everyone. Happy Friday eve.
