Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Oct 26, 2018 at 8:56 AM
    #7001
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    You take mine too, between the both of them you might walk out with a brand new truck:rofl:
    Cativelense[QUOTED] likes this.
  2. Oct 26, 2018 at 9:00 AM
    #7002
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    That would be AMAZING!
    Skierrichy[QUOTED] likes this.
  3. Oct 26, 2018 at 9:04 AM
    #7003
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Nuno, if your sure that your wheels & tires are not the culprit then it most likely is a driveline issue. Like others mentioned it could be your carrier bearing, or a u-joint but it could also be a bad cv joint in one of your front axles. Remember that even when you are in 2WD the front axles are rotating and a bad cv joint can cause a wobble. Good luck figuring it out
    :thumbsup:
  4. Oct 26, 2018 at 9:05 AM
    #7004
    Cativelense
    Nuno
    CT
    Thanks for the input Rob. Adding your input to the list/letter I have typed up to bring with me and hand to the tech.
  5. Oct 26, 2018 at 9:09 AM
    #7005
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Take another copy and tape it to the radio up high on the dash.
  6. Oct 26, 2018 at 9:10 AM
    #7006
    Cativelense
    Nuno
    CT
    Yessir!
    Was thinking about taking a few to be honest... one to hand to the person at the desk, one to tape in the truck, and another one or two just in case.
  7. Oct 26, 2018 at 9:31 AM
    #7007
    Cativelense
    Nuno
    CT
  8. Oct 26, 2018 at 10:39 AM
    #7008
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Hey - you still haven't fixed the error on the 4th arrow. See the gray, should be "an" EGCS bushing.
    ...and "I am willing to do that" or "I would like to do that"? The tech is going to go for a ride, that's a given, question is if they want a chattering owner along for the ride distracting them. o_O
    -English Police.
  9. Oct 26, 2018 at 10:40 AM
    #7009
    Cativelense
    Nuno
    CT
    Alright then, English Police.
    Noted, and fixed.
    LOL
  10. Oct 26, 2018 at 11:29 AM
    #7010
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Good luck man, hope they figure it out!
  11. Oct 26, 2018 at 11:32 AM
    #7011
    Cativelense
    Nuno
    CT
    Thanks Mike! So do I sir... So do I.
  12. Oct 26, 2018 at 12:18 PM
    #7012
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    You are fully aware that this curse will cure itself when you get to the dealer...right?
  13. Oct 26, 2018 at 12:19 PM
    #7013
    Cativelense
    Nuno
    CT
    If it was only that simple... That's what I have been waiting and hoping for, but no such luck since way way before, when it first happened.
  14. Oct 26, 2018 at 12:30 PM
    #7014
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Nuno. I would add your phone number right near where you ask the tech to call you
  15. Oct 26, 2018 at 12:31 PM
    #7015
    Cativelense
    Nuno
    CT
    Yup, already have it there, but didn't want to put it on there for the pic. LOL
    mach1man001[QUOTED] likes this.
  16. Oct 26, 2018 at 12:39 PM
    #7016
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I don't blame you! Lol
  17. Oct 26, 2018 at 1:04 PM
    #7017
    Edgeplay
    Edgeplay Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    Assume you will keep us updated as to what it is. Also when did it start happing milage wise?
  18. Oct 26, 2018 at 1:07 PM
    #7018
    Cativelense
    Nuno
    CT
    Definetely will keep everyone updated.
    I started feeling it before I had the Pro suspension put on, back in April. Back then it was right around 50K, a tiny bit over, and it's about to hit 60k now, so... a little while.
    Been procrastinating getting it checked because it's my daily driver, and I have to drop off and pickup my son at daycare, so it's hard to plan around that. But Monday the wife is taking the day off, so figured that would be the perfect day to drop it off and get it checked since she won't be working.
  19. Oct 26, 2018 at 2:21 PM
    #7019
    tgriff
    tgriff Well-Known Member
    Tim
    CT
    2014 TRD Sport 4x4 Black DCLB
    8.5" x 17" Fuel Hostage black wheels P265/65/R17 Toyo Open Country AT II tires Rigid Industries Dually LED pods on back bumper (Diffused pattern) Rigid Industries 10" SR2 amber LED light bar behind grille (Driving pattern) - Custom mount Magnaflow 18" performance muffler Magnaflow 4" resonator exhaust tip - Welded on 3M 35% tint on front windows Access Limited roll-up tonneau cover Uniden Bearcat 880 CB radio 4' Firestik Firefly CB antenna on Relentless Fab hood mount AVS vent visors Lamin-X amber fog light covers ND4's fog light anytime mod Ultragauge MX 1.3 mounted on dash - Custom mount Weathertech floor liners front & rear Access LED battery-powered bed light CravenSpeed stubby antenna OEM Bed Mat Bosch Icon windshield wipers Plasti-dipped front emblem Debadged TRD Sport bedside decals removed Mud flaps removed
    My truck (same year as yours) has had the same problem for a long time now. The weird thing is sometimes the steering wheel shakes and sometimes it's completely fine. One thing I heard is that you have to make sure your aftermarket wheels are hub-centric and not lug-centric (whatever the f that means lol)
  20. Oct 26, 2018 at 3:03 PM
    #7020
    Cativelense
    Nuno
    CT
    Interesting. Mine does it with stock wheels too though, when I had my winter tires on.
    I'll let you know on here what I find out on Monday, hopefully, so you can have an idea of what might be wrong with yours too.
