Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Mar 30, 2019 at 11:49 AM
    #9461
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    My visit went well. Yours?
    Cativelense[QUOTED] likes this.
  2. Mar 30, 2019 at 12:27 PM
    #9462
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Same. Just hate having people pick at my teeth.
  3. Mar 30, 2019 at 1:43 PM
    #9463
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    New windshield install Wednesday hopefully it goes well.
    TOMB
    Breakfast Taco and Cativelense like this.
  4. Mar 30, 2019 at 5:48 PM
    #9464
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Hi guys, Its been a while since I have posted anything on here. I took my 2010 DCSB to my normal local shop so they can check it out since it just hit 100k miles. The mechanic told me that I need to get a new right rear shock. I asked him about the rest of the suspension and he said that the rest is just showing its age but is fine for now. So this is a great opportunity to get some decent upgrades and a lift since the parts need to be replaced anyways. I am not trying to get a substantial lift. Leveling the front end with 2" overall would be great.
    I had the rear leafs swapped out under the factory recall not to long ago so I know those are fine. I plan on getting 5100s to replace all of the oem shocks and probably bilstein coils since they are also aged. Depending on time and funds I might do it in 2 stages starting with the rear shocks since I need those now.
    Is there anything else on the rear suspension that should get replaced while the truck is up on the lift like bushings? Also, will the truck sit oddly pitched if I only install the rear 5100s even on the lowest setting?
    Is there a link that anyone has showing small parts like bushings and such that should be swapped after 100k for the whole truck?
    The shop will install the rear shocks for just labor charge which isnt terrible, but I dont think I want them to do the front end. I live in the bristol area, does anyone have a favorite shop to get work done at. I will not have the time or space to install the parts myself.
    Thank you guys,
    Erick
    MikefromCT and Cativelense like this.
  5. Mar 30, 2019 at 11:09 PM
    #9465
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    They can pick at my teeth, it's the probing of the gums I don't like & the sucker thing getting stuck.
  6. Mar 31, 2019 at 4:18 AM
    #9466
    Cativelense
    Nuno
    CT
    Morning everyone. Happy Sunday.
    Off to soccer in a bit.
    Breakfast Taco likes this.
  7. Mar 31, 2019 at 4:40 AM
    #9467
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good Sunday morning all. Sunny for now...
    TOMB, Breakfast Taco and Cativelense like this.
  8. Mar 31, 2019 at 4:47 AM
    #9468
    Cativelense
    Nuno
    CT
    Rain and colder coming any minute now...
  9. Mar 31, 2019 at 5:46 AM
    #9469
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Morning gang! Breakfast taco sent me a message this morning to make sure I was still alive. And in fact I am! Busy busy busy here always things to do. Gotta get re-educated this week with some fancy business school at an Ivy League. Glad it’s not coming out of my pocket :spending:
    House work is cranking along here put in a new fence recently to keep the dog out of the street.
    Not much else to report, hope everyone is well!
  10. Mar 31, 2019 at 6:09 AM
    #9470
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    "Break a leg". OH, WAIT - don't. That's the theater. Don't break a leg! :oldglory:
  11. Mar 31, 2019 at 9:39 AM
    #9471
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
  12. Mar 31, 2019 at 11:32 AM
    #9472
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That's the porcelain tile you are talking about, I presume. If so, good call. Did that in my kitchen and hallway. Stuff is very durable..
    I forget the name, but Home Depot sells a grout for it that doesn't need sealing..just grout and go
  13. Apr 1, 2019 at 2:34 AM
    #9473
    Cativelense
    Nuno
    CT
    Morning everyone. Happy Monday. Back to the grind.
    :frusty:
    Breakfast Taco, Roody and WunderSlug like this.
  14. Apr 1, 2019 at 2:43 AM
    #9474
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all.
  15. Apr 1, 2019 at 3:51 AM
    #9475
    WunderSlug
    WunderSlug Well-Known Member
    '17 QS DCLB TRD OR
    Morning folks.
    Did some visual upgrades on Saturday. Not warm enough to derp, but these have been hanging around since Christmas, so I figured it was time.
  16. Apr 1, 2019 at 4:02 AM
    #9476
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    Anyone planning on going to Lime Rock Park Race Track on April 6 for Opening Day? Free Admission and free parking. Charity club races, parade to help the Michael J Fox Foundation. Great event for a wonderful cause. It will be nice to see you there. :)
  17. Apr 1, 2019 at 5:34 AM
    #9477
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Lime Rock rules, used to be a volunteer there for race weekends...would love to make it (esp given the charity being supported) but that's my wedding day :eek:
  18. Apr 1, 2019 at 5:37 AM
    #9478
    Cativelense
    Nuno
    CT
    SHIET!!!!!!!!! Congrats Ross!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  19. Apr 1, 2019 at 5:40 AM
    #9479
    Roody
    Ross
    SW CT
    GX460
    Thanks Nuno!
  20. Apr 1, 2019 at 5:57 AM
    #9480
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Monday again.
    But on a positive note, finally have a functioning cb.
    I tried doing a nice hidden install, by putting it in the center console. Unfortunately the radio I was using was gifted to me, and was fried.
    I was wheeling with @Skierrichy and an FJ from the OB forum a couple weeks back, and Alex in the fj had a cb that he wasn’t using.
    I’d like to still grab another radio and finish the install in the center console, especially after all the effort, but I’m happy to have a functioning (and free) radio for the trails for now. Got the antanne all tuned and ready to go!
