Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Apr 5, 2019 at 4:12 AM
    #9541
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    Take your time doing the chop, measure 3 times and cut once. If your going to weld a replacement metal tab back on, disconnect the battery, better yet, remove the PCM from the truck. Bevel all metal edges before laying a bead, ground the welder as close to the weld area as practical. After welding use a good quality epoxy primer and black chassis paint to prevent rust. For added protection coat the entire area, blend in, with a quality rustproofing layer of smootz!! Overkill ? Yes, but worth it not to have any issues during or after the modification. Strictly your call. :mudding::oldglory: Enjoy, have fun !!
  2. Apr 5, 2019 at 5:04 AM
    #9542
    WunderSlug
    WunderSlug Well-Known Member
    '17 QS DCLB TRD OR
    Happy Friday all. 4 day work week next week!
  3. Apr 5, 2019 at 5:05 AM
    #9543
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    :jellydance::jellydance::jellydance:
    WunderSlug[QUOTED] likes this.
  4. Apr 5, 2019 at 5:18 AM
    #9544
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Going to be welding sliders on in the next couple months
    I know to disconnect the battery; can you elaborate on disconnecting the pcm, for a noob. :bananadead:
  5. Apr 5, 2019 at 5:57 AM
    #9545
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    This is exactly what were planning:thumbsup:
    MikefromCT and Cativelense like this.
  6. Apr 5, 2019 at 5:58 AM
    #9546
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Well then you should have gotten 5! :anonymous:
    Bridge4 and Cativelense[QUOTED] like this.
  7. Apr 5, 2019 at 5:58 AM
    #9547
    Cativelense
    Nuno
    CT
    :rofl::rofl::rofl:
  8. Apr 5, 2019 at 6:04 AM
    #9548
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    with good reason - those philly parking cops are aggressive with a boot or tow. Watch the signs - read twice, park once. :devil:
  9. Apr 5, 2019 at 6:04 AM
    #9549
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    I think he means the giant plug near your hood latch, unplug it.
    This is what I do anyway with the disconnected battery:thumbsup:
  10. Apr 5, 2019 at 11:03 AM
    #9550
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    With the PCM disconnected or better, removed from the vehicle before any welding, this totally eliminates any chance of a voltage spike from frying your PCM. Seen many vehicles after frame or body welding that would not start due to a faulty fried PCM.
  11. Apr 6, 2019 at 4:50 AM
    #9551
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Morning.
    Headed to work in a few to remove the ratty old carpet in the Tacoma and clean the floor. Have a new carpet to put in.
    I may also sound deaden the roof/back wall and remove the stock flares, depending on how much time then carpet takes.
    I also have some small parts to install which won't take long at all.
  12. Apr 6, 2019 at 5:56 AM
    #9552
    Cativelense
    Nuno
    CT
    Morning everyone. Happy Saturday.
    Nice!
    Breakfast Taco likes this.
  13. Apr 6, 2019 at 5:58 AM
    #9553
    MikefromCT
    CT
    2013 TRD OR DCSB
    Morning all!
    Round of disc golf in the am; and indoor rock climbing this afternoon.
    Gonna be a good day.
  14. Apr 6, 2019 at 6:23 AM
    #9554
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    May you find no signs of rust or damage under the rug & behind the flares! Good luck.
    Bridge4 and Cativelense like this.
  15. Apr 6, 2019 at 6:26 AM
    #9555
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Around here that disc golf would be pick up sticks & throw on brush pile.
    The rock climbing is called rock stacking as the wall always needs attention in the spring.
    Have fun!
  16. Apr 6, 2019 at 6:30 AM
    #9556
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Happy weekend all.
    WunderSlug and Cativelense like this.
  17. Apr 6, 2019 at 7:22 AM
    #9557
    WunderSlug
    '17 QS DCLB TRD OR
    We won last night! Smoked em 7-2. That was the team that won the playoffs last season. Felt good to lay a beating on them.
  18. Apr 6, 2019 at 7:39 AM
    #9558
    MikefromCT
    CT
    2013 TRD OR DCSB
    Don’t you mean CrossFit?
    Cativelense likes this.
  19. Apr 6, 2019 at 7:54 AM
    #9559
    Cativelense
    Nuno
    CT
    Fucking pissed... Shitty way to start the weekend.
    Boss asks me to do something, as well as her boss. So I get on the laptop to do that, to then see a bullshit email from a sales person throwing shade. And to add insult to injury, he adds at the end "I would love to say more but I won't". Who the fuck do you think you are?? Not my fault your stupid ass, and your stupid ass assistant don't know how to do your job. So I respond back, CC my supervisor, and proceed to ask him to do say more because I would like to know, and explain to him that NO, his assistant didn't do what he is claiming she did, asked for that email that he is claiming she sent, and told him that if he has a problem he can speak to my supervisor and I will address it with her.
    Then I sent my supervisor a separate email, attached another email from this stupid ass salesperson to show that this is the 2nd time in as many days that he tries to get "cute" with me, and tell her how I feel about this, how I feel about the entire job/situation with people constantly giving me shit for trying to do my job, complaining about me behind my back, and that I'll gladly put in my two week's notice.
    Fucking done and fed up with this bullshit and the people I have to deal with on a daily basis.
    Bridge4 and TOMB like this.
  20. Apr 6, 2019 at 8:15 AM
    #9560
    ptat
    ptat Well-Known Member
    2019 Tacoma SR5 4WD DCLB
    Sounds like a stressful job.
    Email passive aggressiveness is just the worst.
