Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jun 4, 2019 at 3:04 AM
    CurtisLoew
    CurtisLoew Well-Known Member
    2018 TRDPRO
  2. Jun 4, 2019 at 4:05 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Thank you guys! It was a great last day off before getting back to the grind.
  3. Jun 4, 2019 at 4:12 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    Welcome back, been in touch with Alex possible wheeling last weekend in June.:thumbsup:
    MikefromCT and Cativelense like this.
  4. Jun 4, 2019 at 4:33 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    :rofl::rofl::rofl:
  5. Jun 4, 2019 at 9:20 AM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Happy belated birthday @mhoadley .
    Couple hours at work Monday ended up being longer day than normal shift. Good I went in, I was needed.
    Stopped in at night job to do a quick audit, ended up staying 15 minutes longer than a normal shift. Good I went in, I was needed.
    To hell with them today - rest of the week is mine!
    Went to the local welding shop finally this am. He'd be happy to weld/blow holes/take my money trying to fix the tundra, but suggests I first see if my mechanic can source a used axle housing. Guess I'll be getting out the wire wheel & JB Weld. LOL.
    Happy Tuesday all.
    CurtisLoew, MikefromCT, TOMB and 3 others like this.
  6. Jun 4, 2019 at 10:55 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Thank you!
  7. Jun 4, 2019 at 4:22 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    After 6 years i finally i stalled the AC drain extension .
    Just need to attach it with tie wraps.
    Just need a widget from the hardware store to complete the install. Pic to follow.
    TOMB
  8. Jun 5, 2019 at 2:41 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone. Happy hump day.
  9. Jun 5, 2019 at 2:47 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning all
  10. Jun 5, 2019 at 3:19 AM
    CT18Tacoma
    CT18Tacoma Well-Known Member
    Ray
    2018 TRD Sport
    Morning everyone. :pccoffee:
  11. Jun 5, 2019 at 4:42 AM
    CT18Tacoma
    Ray
    2018 TRD Sport
    This is on the top of my list. Looks pretty simple. Any issues with the install?
  12. Jun 5, 2019 at 5:17 AM
    CT18Tacoma
    Ray
    2018 TRD Sport
  13. Jun 5, 2019 at 5:45 AM
    Cativelense
    Nuno
    CT
    So on the way in to work this morning, my friend whose grass I cut called me...
    Was telling me that his septic had been smelling up a bit, and that water looked like it was coming from the top of the tank, where the lid is. Said he called the septic people about a warranty since he had actually gotten some work done and something replaced about 5 years ago, some pump, and that the warranty was only for a year and that they no longer worked with that guy but recommended someone else. So he called them, and they told him how much it would be to replace that pump if it crapped out. Before he made an appointment for them to come out, he remembered something and went out to check it first before making an appointment.
    Well... on the side of his yard there is this electrical type box that comes out of the ground, with a plug plugged into it. I see it and not quite sure what it is, so I try to obviously be careful when I go near it with the mower and the weedwacker. Turns out that it was unplugged. Somehow I must have ended up touching it with either the corner of the deck or the string from the weedwacker. I honestly don't remember touching it, and when I noticed it was already unplugged, but somehow I must have done it.
    He plugged it back in and it's working now and pumping out the tank to the leeching fields. He needs the pump because of the way his backyard is, and the fields are up on a little hill, so he needs the pump so that it pumps the water up the little hill and into the fields.
    Needless to say my heart dropped and I felt like absolute SHIT when he told me what happened, and why it had happened. Septic issues aren't cheap, and if I fucked his up not only would I obviously pay for it, but I would feel even worse for having fucked it up. He kept telling me that it was all good, that he didn't even think to tell me about the box in the first place to be careful with it, and that it looks like there is no problem and the pump is working and doing what it's supposed to, and draining out to the fields. Said if he knew I would react like this, he never would have said something. I still feel like shit, kept apologizing, and sent him a text apologizing again as soon as I got to work. He said it's all good, but still...
    FML. Try to be careful, try to do a good thing (even though he is paying me, I still offered to cut it for him since he said he didn't want to pay someone else that he didn't know and would rather pay a friend), and still manage to somehow fuck shit up. I guess no good deed goes unpunished, sort of... FUCK. I really hoping nothing bad happened and came of it. Not because of having to pay, but because of possibly ruining a friendship.
    :annoyed: :frusty:
    Bridge4 and Skierrichy like this.
  14. Jun 5, 2019 at 6:05 AM
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    Shit happens
    Could have been worse.
    Shit tons worse:rofl:
  15. Jun 5, 2019 at 6:10 AM
    CT18Tacoma
    Ray
    2018 TRD Sport
    Don't sweat it man! That was an easy fix! That's the business I'm in. We manufacture water and waste water pumps worldwide. I use to install/service that stuff back in the day, you didn't fuck anything up, just removed power for a bit lol Once it pumps the tank back down it will operate like normal.
  16. Jun 5, 2019 at 6:13 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  17. Jun 5, 2019 at 6:23 AM
    Cativelense
    Nuno
    CT
    :rofl::rofl::rofl:
    :fingerscrossed:
    Skierrichy[QUOTED] likes this.
  18. Jun 5, 2019 at 8:56 AM
    TOMB
    Tom
    Newington Ct. 06111
    CT18Tacoma
    The only issue is ,
    I should have done the mod BEFORE the Fluid Film was applied
    Thank God there is Lava soap.
    Just need a widget to make the final attachment on the frame.
    If you take your time it will take you less than 10 minutes.
    TOMB
  19. Jun 5, 2019 at 9:35 AM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Chances are it took awhile to fill the tank enough for him notice an issue. Could have been Bambi kicked it out, could have been kids running about, could have been squirrels running/wrestling, could have been you. Don't worry about it, or put up some edging & drop some green gravel around it. No harm, no foul, poor design, lesson learned, beautiful day today!
    Good Noon everyone!
  20. Jun 5, 2019 at 9:38 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Honestly Nuno,
    Don't worry about it. The neighbor should actually take some precautions to prevent that, such as a protective fully enclosed lid over the outlet and plug.
