Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Oct 29, 2019 at 2:43 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  2. Oct 29, 2019 at 2:52 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone. Happy hump day eve.
    Yesterday was fucking brutal at work. Expect nothing less today. Let the shit show # 2 begin.
    Yesterday really had me thinking about putting my notice in... It was that bad.
  3. Oct 29, 2019 at 3:04 AM
    CT18Tacoma
    CT18Tacoma Well-Known Member
    Ray
    2018 TRD Sport
    Mornin everyone.
  4. Oct 29, 2019 at 4:08 AM
    WunderSlug
    WunderSlug Well-Known Member
    '17 QS DCLB TRD OR
    Morning all...
  5. Oct 29, 2019 at 5:26 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Good morning Ct and across the borders,
    Planning on doing some cleanup on the sliders from this years use, and make sure that the inside of the frame is well coated from welding those on. I initially sprayed the inside of the c channel sections of the frame, but I never was able to get the inside of the front tube section of the frame where the front mounts are; someone recommended Eastwood internal frame spray, so I’ll be ordering that up.
    When my brother welded the sliders on, he was able to get the sides (including the angle up), and the bottom parts of the welding plate welded real clean, but was not able to get enough room to weld the small top part. It’s definitely strong enough as it currently is, but I’m looking to seal that top section to the frame, really to keep road spray out. What would you all recommend for this application? I was think jb weld or epoxy but wanted to see all of your thoughts.
    Picture below of the General shape of the welding plate that I’m talking about
  6. Oct 29, 2019 at 5:37 AM
    zachshere
    zachshere Well-Known Member
    Can't like this one, hope your week gets better.
  7. Oct 29, 2019 at 5:44 AM
    Cativelense
    Nuno
    CT
    Thank you sir. But doubt it will... co-worker took the entire week off, so it can only get worse.
    Don't get me wrong, I don't care if he takes time off. What I do care about is the fact that I have to cover for him and a lot of the stuff that he "covers" I know NOTHING about, but yet I'm still the backup person, even though I was never trained on it. The daily volume is already crazy as it is (yesterday I was easily at over 300 inbound emails that I read every single one), but then when you don't know anything about something and you are getting asked all these questions, and it takes several emails back and forth to get information, and you're questioned about shit like that, and questioned about shit that you do cover and you tell people what to do but yet they push back on you and go "crying" to your supervisor about, that's when it gets even more annoying. Not to mention that some of the shit he handles, the stuff that I know NOTHING about, used to be handled by someone else... so why can't that other person cover that while he's out, and I do the rest?!?!?! I guess it would make too much sense to split it up... but it's not my place to say anything, so I have to keep quiet. But, if I do get asked, you better believe I'll say something. I've had enough.
    I gripe about work a lot, I know, especially when my co-worker is off and I cover, but that's when everything comes to a boiling point because I'm stretched too thin, and I realize how much I don't know about certain things that I am asked to do/cover on... I'm only one person trying to do two people's job. It's not fun.
    Bridge4, CurtisLoew and WunderSlug like this.
  8. Oct 29, 2019 at 5:51 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    woof. Good luck Nuno
  9. Oct 29, 2019 at 5:52 AM
    Cativelense
    Nuno
    CT
    Thanks Mike!
  10. Oct 29, 2019 at 7:01 AM
    Tacoman589
    Tacoman589 Well-Known Member
    2020 Army Green TRD PRO
    i got a pro but got it for 45,750. so I’m pretty sure its just the truck. I got a tri fold for 300. Im thinking of adding the bed mat, sill protectors and maybe the remote lock on the tailgate? Im going to do aftermarket weather mats and running board.
    This is my first Tacoma so I apologize for the dumb question...but do they come standard with a remote start? And do most people go aftermarket or OEM?
    WunderSlug and Cativelense like this.
  11. Oct 29, 2019 at 7:36 AM
    WunderSlug
    '17 QS DCLB TRD OR
    If you do this, use the one in the article I referred to earlier. (https://tacomadepot.com/the-top-10-things-that-should-have-come-standard-on-your-tacoma/
    It says for a Tundra, but there's a TW member that used it and confirms it works.
    They are not standard. The OEM starter was quoted at $375 for my 2017. The aftermarket is $175. I THINK the only difference is that the aftermarket starter kills the engine as soon as you open the door. I don't believe this happens with OEM. Someone will correct me if I'm wrong.
  12. Oct 29, 2019 at 9:01 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    3M body seam sealer. It stays pliable and is made to seal joints in automotive bodies.
  13. Oct 29, 2019 at 9:17 AM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Thank you sir!
    zachshere, WunderSlug and Cativelense like this.
  14. Oct 29, 2019 at 4:32 PM
    zachshere
    Hullo! Joy of Joy, I got my official Toyota letter regarding my frame. I have had heated discussions from friends regarding this issue. I went through it with my 2007. I still stand behind Toyota that they are following through on this issue. My 2007 had perforations and when I declined to have the frame replaced I was given a very fair trade in offer. I have kept an eye on the frame of my 2015 and see no signs of corrosion but think next time I go in for a service will have them take a look.
  15. Oct 29, 2019 at 4:55 PM
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    What kind of fucking machine are you running?
    Cativelense[QUOTED] likes this.
  16. Oct 29, 2019 at 5:10 PM
    JeffB
    Jeff
    N.E. CT
    2017 TRD Sport
    That sucks,
    In my job I have people in the Midwest making decisions of what software to use, I try getting help on software at 7AEST.
    Cativelense likes this.
  17. Oct 29, 2019 at 5:34 PM
    Cativelense
    Nuno
    CT
    Sucks when (what I feel is not right) work gets all thrown on one person because the other is out, and your "team" only consists of two people. Especially with the line of the business that we handle... It's constant movement all day, tons of emails, phone calls, back and forth... Unlike the others (I think) which don't have the constant movement that ours has.
    JeffB likes this.
  18. Oct 29, 2019 at 8:53 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    So, is it the same shit show when you are off?
    Sounds like demanding some more training would help, but if you don't do it - training only goes so far.
    Maybe you can convince mgt to get that other person to cover for 2nd 1/2 of the day, help wrap the mess up each day.
    You know from your buddy - we're looking for seasonal help. :cool: But going forward weekends would be required. :(
  19. Oct 30, 2019 at 2:39 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning all...
    Hang in there Nuno!
  20. Oct 30, 2019 at 2:49 AM
    Cativelense
    Nuno
    CT
    Morning everyone. Happy hump day.
    If I could get someone to cover the shit that I don't know anything about, and that person would be the one that used to do that stuff anyway, that alone I think would be a great help. But I don't think it's up to me to say or do anything because technically that person is not part of our team, and has her own supervisor, etc. My guess is that it's the same type of shit show when I'm not there, but not certain... Chances are it's not because I feel that what I handle is pretty easy and straightforward, so it's not very hard to handle. The stuff that the other person handles that I know nothing about on the other hand... That's hard to me at least, and that's where I get bogged down the most I feel.
    It's just a fucking mess (in my opinion)... They'll never hire anyone else, and they'll never ask if we need help. It's the whole mentality of "do more with less". It won't change.
    steele-taco likes this.
