Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Mar 29, 2020 at 11:43 AM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    I would be careful with retrofits. In hindsight I would only buy them from an actual business. I bought some and didn't have a great experience with the seller.
    lynyrd3, Bridge4 and Cativelense like this.
  2. Mar 29, 2020 at 11:49 AM
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    I would only do OEM for the headlights... not worth the moisture issue
  3. Mar 29, 2020 at 11:50 AM
    GMAN62465
    Gary
    not enough $$$ for both lolol
    lynyrd3 and Cativelense[QUOTED] like this.
  4. Mar 29, 2020 at 1:26 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I had someone do retrofits in an old truck of mine, the entire electrical system went bonkers and even with new wiring from dealer still was messed up. NEVER AGAIN!!!!:annoyed::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    lynyrd3 and Cativelense like this.
  5. Mar 29, 2020 at 3:03 PM
    aStrauss
    aStrauss Well-Known Member
    Andrew
    2019 TRD OR DCSB 6MT
    Met a TW member down in NY this morning to pick up a new set of wheels, super excited with how they look.
    Skierrichy, lynyrd3, TOMB and 4 others like this.
  6. Mar 29, 2020 at 3:09 PM
    Bridge4
    MA
    what are those! I really like those wheels.
    WunderSlug, lynyrd3 and Cativelense like this.
  7. Mar 29, 2020 at 8:34 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    An early good morning and a late good evening!
    TOMB
  8. Mar 29, 2020 at 9:00 PM
    GMAN62465
    Gary
    Hey there TOMB!
  9. Mar 30, 2020 at 2:34 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning all. Off to work...
  10. Mar 30, 2020 at 4:10 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut ,stay safe out there . :hattip:
    Breakfast Taco, vssman, TOMB and 2 others like this.
  11. Mar 30, 2020 at 4:13 AM
    lynyrd3
    Bill
    Nice :thumbsup:
    Breakfast Taco, TOMB and Cativelense like this.
  12. Mar 30, 2020 at 4:45 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Monday.
  13. Mar 30, 2020 at 5:12 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Good morning everyone,
    Back to the grind for the week.
    I spent some time researching lift kits this weekend. Probably going to pull the trigger on a kit with bilstein 6112’s up front with 5160’s in the rear mated with ome dakar leaf packs. Pretty sure Ill be going with the Camburg ball joint uca’s; from what I’ve read, ball joints are the way to go around areas with road salt.
    With the lift comes the need for extended brake lines, as well as the ecgs bushing.
    Any recommendations what to go with for extended brake lines? And would anyone happen to have the ecgs needle bearing puller and the install tool?
    Bridge4, Breakfast Taco, TOMB and 2 others like this.
  14. Mar 30, 2020 at 10:14 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    Well I had a nice 3 day weekend. Got to relax for a little bit, start some spring cleaning, along with getting some time on Iracing. We took the winter plastics off of the windows and the weather was decent enough that we were able to open up the rest of the windows to air out the whole house. Talk about kicking up some extra dust, jeez. It doesn't matter how much you clean and run air purifiers during the winter, there is always something that's dusty lingering around.
    Back to the work grind. :turtleride:
  15. Mar 30, 2020 at 7:16 PM
    GMAN62465
    Gary
    And lights it is for the Win!
    Ordered and on the way... :D
    My OEM set will be up for sale soon
  16. Mar 30, 2020 at 8:59 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Good something or other all.
    TOMB, lynyrd3, vssman and 2 others like this.
  17. Mar 31, 2020 at 2:36 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Good morning boys
  18. Mar 31, 2020 at 3:56 AM
    lynyrd3
    Bill
    Morning Connecticut :hattip:
    TOMB, vssman, Sand Dog and 2 others like this.
  19. Mar 31, 2020 at 4:47 AM
    Cativelense
    Nuno
    CT
    Morning everyone.
    Happy Tuesday.
    lynyrd3, TOMB, vssman and 2 others like this.
  20. Mar 31, 2020 at 12:04 PM
    WunderSlug
    WunderSlug Well-Known Member
    '17 QS DCLB TRD OR
    Afternoon all...
    lynyrd3, TOMB and Cativelense like this.
