Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Jun 3, 2020 at 4:46 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone.
    Happy Tuesday.
    Gonna check on the headlights a bit later on, once everyone is up so I can open the garage door.
    lynyrd3, TOMB, vssman and 2 others like this.
  2. Jun 3, 2020 at 5:23 AM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Morning all
  3. Jun 3, 2020 at 5:34 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    @Cativelense
    1) How did the stump grinder work? Any pictures? I want to rent one as I have a ton of stumps on our property I need to grind down and a few are fairly large. Wondering how long it took to do them.
    2) I did retro's on a truck, they went crazy and destroyed most my trucks electrical system. gotta be careful with those!!! Good luck getting it right. :thumbsup:
  4. Jun 3, 2020 at 5:38 AM
    Cativelense
    Nuno
    CT
    Stump grinding went OK actually. I only had a few to do on my property, and they were small, so it was quick. My neighbor (since we split the rental), had a lot more than me, and way way bigger. Still went OK, just took a lot longer. But aside from that, easy peasy. We rented the "middle" size machine, but I'm sure if we rented the bigger one it would have been quicker for his. But all good either way. He had a couple that took about an hour each, that's how big they were. If you have some large ones, I'd say go for the bigger unit. It'll be much much quicker.
    About the retros... I hope I got it right. So far I think I did, since I tested it last night, but we'll see. Gotta check on the lens clearing/cleaning thing though. Gonna go down there in a bit. The kids are finally up, so free game on making all sorts of noise.
  5. Jun 3, 2020 at 5:48 AM
    Bridge4
    MA
    Thanks for the tips, I have a couple that really are big, but 85% are pretty tiny, but it sounds like a bigger one will be worth it to save some hours. Glad to hear you got the retros maybe figured out!
  6. Jun 3, 2020 at 5:49 AM
    Cativelense
    Nuno
    CT
    You might be able to get away with the "medium" size machine then, if you have that many that should be a breeze. But it all depends on how much they want for the larger one as well. That made a difference when we rented ours. Went with the medium because they wanted a lot more for the bigger one.
    lynyrd3, Breakfast Taco and TOMB like this.
  7. Jun 3, 2020 at 5:57 AM
    Bridge4
    MA
    Yeah they get pricey which is why I haven't done it yet. I have about a mile of trail I want to grind every stump off of, then there is a cleared area that was logged years ago I want to clean up all the stumps in. I was thinking it was going to take me close to a week. There has to be a trade off on time saved/cost per day though. I'll have to go talk to my local rental places and see whats what.
  8. Jun 3, 2020 at 7:02 AM
    Cativelense
    Nuno
    CT
    Man! I'd say the stuff looks like it did a damn good job! No signs of the "peeling". Should have taken a before pick so you peeps could see for reference.
    But it looks like the spray stuff ran onto the bumper, but just on one side... DOH! Now I have to find a way to clean this off, without fucking up the paint.
  9. Jun 3, 2020 at 10:56 AM
    Cativelense
    Nuno
    CT
  10. Jun 3, 2020 at 1:23 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Getting ready for some tractor maintenance tomorrow.
    Getting the footbrake lever relocated so it works better for my reach.
    A friend of mine is helping, he built his own biplane( a Stolp Starduster 2 and i think he is proficient in aircraft welding.
    Knowing how he works my mod will be overbuilt and over engineered.
    I'm not going flying with the tractor but i know his repair/mod won't break either.
    Pic tomorrow.
    TOMB
  11. Jun 3, 2020 at 2:48 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    :anonymous: Somebody’s birthday in this thread today:notsure:
    lynyrd3, Breakfast Taco, TOMB and 2 others like this.
  12. Jun 3, 2020 at 2:50 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  13. Jun 3, 2020 at 2:55 PM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    ayy thanks guys!
  14. Jun 3, 2020 at 3:00 PM
    Cativelense
    Nuno
    CT
    How the fuck did I miss that?!?! DOH!
    Happy birfday @mhoadley !
  15. Jun 3, 2020 at 5:18 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Joe Lauzon would approve.
    Hmmm maybe a light hit of clay bar?
  16. Jun 3, 2020 at 5:32 PM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Thank you Nuno!
  17. Jun 3, 2020 at 6:33 PM
    TOMB
    Tom
    Newington Ct. 06111
    @mhoadley
    29 again?
    Happy Birthday!
    TOMB
  18. Jun 3, 2020 at 7:10 PM
    Cativelense
    Nuno
    CT
    LOL!!
    Yeah, maybe on one of my Tuesday's off, I'll actually clean the truck from top to bottom.
    lynyrd3 and Breakfast Taco like this.
  19. Jun 3, 2020 at 8:33 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    I would bet those grinders sit a lot. probably can negotiate a deal for a week or longer, maybe free size upgrade.
  20. Jun 3, 2020 at 8:41 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
