Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Aug 19, 2020 at 8:56 AM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Think they will spray a replaced frame? Is there a TSB out there to read on this?
    GMAN62465 and Cativelense like this.
  2. Aug 19, 2020 at 9:05 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Just fluid film it.
    I havent to date but Ill be starting that this year after seeing everyones results. I have a little clean up to do on my frame before I do it however. Nothing bad but cleaning up any surface rust first will give me peace of mind. I plan on tackling that the week I took off to the lift. And hopefully a regiment of fluid film twice a year (before winter, and spring).
  3. Aug 19, 2020 at 10:15 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Tests are done on all 4 of us. Now we wait.
    Said this one was better/easier than the way it was done before. Doesn't need to go as far up your nose. But they swirl it around in each nostril for 15 seconds on each side. Tickled like a mofo. Kids both cried hysterically, obviously.
  4. Aug 19, 2020 at 3:37 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  5. Aug 19, 2020 at 6:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    If you pass they spray. What year, I forget..you then get a second inspection before 12 years from date the truck was first put on the road as a result.
    Hard dislike
    No clue on the replaced.
  6. Aug 19, 2020 at 8:32 PM
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    Sorry to hear that Nuno.... Best wishes for a speedy clean report back... Prayers coming your way
    G
  7. Aug 19, 2020 at 8:35 PM
    GMAN62465
    Gary
    Happy Birthday @TOMB
    Sorry I missed it... looks like there was a lot of fire on that cake!
    I hope you enjoyed the day with close family and friends as best as possible
    Was that #34 or #35??
  8. Aug 19, 2020 at 8:35 PM
    Cativelense
    Nuno
    CT
    Thanks so much Gary. Nothing we can do but wait. I fucking hate waiting.
    Breakfast Taco and lynyrd3 like this.
  9. Aug 19, 2020 at 8:52 PM
    GMAN62465
    Gary
    OK.... about my earlier lift post
    I am looking to place an order for my lift parts for my 2015 4x4 DCSB Tacoma.
    Looking at this
    Bilstein 6112's in the front, 5160's in the rear, 3 leaf AAL and a set of JBA uca's
    Looking for 2 - 2.5 inches from what I have... choices for front shock settings are listed below.
    Should I do the front coil settings as #4 or number #5... Is there any reason I should not go top setting on the front shocks??
    Just starting to order parts to move things along... maybe 3 weeks to a month before the stuff would be available at this point.
    Thoughts? Advice?? Words of encouragement?
    Thank you all in advance
    FRONT LIFT CHART
  10. Aug 20, 2020 at 1:45 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I was reading the CRC application thing and it says when they clean and dry the frame, if there is a hole found, they replace the frame.
    Hopefully the tech doesn't over look this. I for one will be inspecting my frame (on a lift) when I get it back from Toyota.
  11. Aug 20, 2020 at 2:33 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all
  12. Aug 20, 2020 at 2:33 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :wave:
  13. Aug 20, 2020 at 2:41 AM
    lynyrd3
    Bill
    I have 6112s at the top setting with Total Chaos UCAs for 3 years . No problems. You will feel larger road bumps a bit more up front ( pot holes ) and speed bumps . Other than that I like it! Also have medium duty Dakar’s with an AAL in the rear with 5125 Bilsteins for 2-3” lift . Don’t forget extended brake lines . I might purchase some Timbren bump stops up front ,it might help with road bumps :notsure: I have the Timbren SES bump stops in the rear and they are great for towing .
  14. Aug 20, 2020 at 2:46 AM
    lynyrd3
    Bill
    Good luck , hopefully at worst all you will have to do is self quarantine for 2 weeks .
  15. Aug 20, 2020 at 2:57 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    have them on my first gen. go one knotch higher than you want because they do settle and lose height after first couple hundred miles
  16. Aug 20, 2020 at 4:29 AM
    Cativelense
    Nuno
    CT
    Morning everyone. Happy Friday eve.
    Hoping for not even that!
  17. Aug 20, 2020 at 1:44 PM
    ABA180
    East Bridgewater MA
    Truth. If they find a hole, they fail it and get a replacement. If it doesn't have the hole they apply the CRC
  18. Aug 20, 2020 at 3:21 PM
    Banggerr
    Banggerr Well-Known Member
    Anybody from the Thomason/Litchfield area? See a lot of tacomas!
  19. Aug 20, 2020 at 5:08 PM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    My girlfriend's (Where I am 75% of the time) is in Naugatuck so you may see me around sometime! Is it true Thomaston dam is motorcycle only?
    Also, newest mod! GIve me a honk if you guys spot me
  20. Aug 21, 2020 at 3:32 AM
    Ranger357
    Ranger357 Well-Known Member
    Ken
    Peoples Republic of Connecticut
    2018 TRD Off Road
    Bilstein 5100's OME 888's JBA UCA's Torch Off Road AAL Cavalry Mud Terrain 265-75-16
    HONK !!
